Piezo-Azden-Acutex Thread
Then you'll love the M320 STR if the original stylus is intact and not worn.
Joseph will steer you in the right direction.
Athanasios
i do hope so and that the price is right. any other stylus that is good if he cant fix?
have u compared it to the stanton 881s cartridge?
i guess my sme arm is mostly for MM pickups right? so maybe not a good idea to pair it with the emt either? or another mc pickup like ortofon mc 20 super or the 30 version?
The TRX were the highest order embodiment, or version of the Tripole design.
But as I’ve shown and discussed before, the Tripole is merely a different version or incarnation of the AT V magnet design. There is no difference. The Acutex just moved 2 of the 4 AT poles forward of the magnets. There is no magic.
The AT 4 poles, 2 each side of a V magnet:
The AT V magnets:
Acutex. The red arrows point to the poles placed where the AT poles are. The black arrows point to the 2 poles moved forward. The Acutex uses a single-piece metal sleeve with 2 ears. The ears work identically to AT’s V magnets, and so does the metal sleeve. The sleeve is read by the 2 poles moved forward from AT’s original position. All 4 Acutex poles read the exact same movements as AT’s 4 poles. No magic. No difference.
The AT V magnets:
Appreciate your detective work. However, Acutex cartridges do sound different than ATs.
Well, of course it depends on *which* AT carts, and which Acutex carts, and which tonearm, etc. My Acutex 310 sounds identical to to my AT12XE when I have the bonded elliptical stylus mounted on the 12XE.
It’s no secret that AT sued Acutex for patent infringement. AT “lost” the court case, but put Acutex out of business.
I would go as far to say better than at's.
I had the AT12xe with the top stylus( I think Shibata) and it was way too harsh for me compared to the Acutex M320 STR original stylus.
But our hearing is all different.
I just prefer the Acutex from the AT's I have heard. Even with the lowly replacement bonded ellipticals out there.
Athanasios
The AT12XE was a nude elliptical, hence the XE name.
That’s why I compared the 310 to the XE with a bonded elliptical stylus. Apples to apples comparison. The 320 compared to the 12XE with its original stylus is an apples to oranges comparison.
Other than possible stylus tip geometry, the Acutex are for all intents and purposes, AT cartridges. No magic. No “Tripole”. Just marketing glitz by Acutex. That’s why AT sued them. And yes, AT was suing another Japanese company, and an American company. AT hasn’t sued many companies.
Regards.
Acutex cartridges are IM, not MM. The original brochure can be viewed at:
https://www.turntableneedles.com/assets/images/eprod/acutex/acutex_cartridges.pdf
There is much discussion at Lenco Heaven, search for "The Acutex Bar" thread.
The 400 series is also an IM design, the "third pole" function is nicely described in the TTN link.
Eight or so years ago, a cache of Acutex cartridges were offered by a vendor, often referred to as "The Italian Seller".
I just now unboxed a NOS 420STR from that vendor, the accompanying brochure confirms both the IM and tri-pole design.
Hope this is helpful,
Peace
Who was saying Acutex carts are MM?
But in reality, MI carts ARE just a subcategory of MM. They use virtual, or temporary moving magnets instead of permanent moving magnets.
Regards.
Peace
Can you post the documents that say that? I have always understood the 4xx series were not Tried-Pole design
nashou
Regards, Wolfie62:
My recent post was intended to be informational, not argumentative. As to the LPM400 series Acutex being MM, it's frequently stated as such. Having read it on the Lenco Heaven site quite a while back, I'm guilty of such in this thread several years ago, IIRC. I set my son up with a 412STR and actually read the brochure, it's definitely IM. Mea culpa.
For those interested, in your post, #687 in this thread the disk shaped magnet associated with IM carts is evident.
Peace,
Regards, Wolfie62:
Peace,
No argument from me. But whether the 400 series STR is MM or MI is splitting hairs. All MI carts are MM in theory, operation, and in reality.
MI carts merely move the permanent magnet off the cantilever and replace it with a temporary magnet. Still a magnet moving between pole pieces.
When you understand magnetics and magnetic circuits, the line between MM and MI is removed.
Peace
Shalom
Peace
Help me understand, your saying MI but the Acutex is an IM or induced magnet.Is there a difference, or not, between a moving Iron and an Induce magnet .?
Athanasios
Athanasios
None whatsoever. Moving Iron, Magnetic Inductance, Variable Reactance, Variable Reluctance, Induced Magnet, Variable Magnetic Shunt, Magnetic Flux Valve, they are all the same.
They all work the same. A remotely mounted permanent magnet is used to fill up a soft iron (permalloy, Mumetal, or heat-softened steel) piece with its magnetic flux field. This magnetic-filled piece is now a magnet as long as it’s in the vicinity of the permanent magnet. That magnetic flux-filled piece moves between the coil poles to generate a voltage; the voltage corresponds to the groove modulations.
MI is just a way to move the heavy magnet off the cantilever. But you’ll find a commonality in all MI cartridges: The permanent magnet is large and powerful, or small and powerful. It is powerful enough to saturate the soft iron piece with as much magnetic flux as it can handle. So there is no loss in magnetic strength as the cantilever moves up and down, back and forth between the pole pieces.
Therefore, an MI cart is still a MM cart in principle, theory, and reality.
Peace
Shalom
Regards, Nashou66:
Sorry, flip phone & unable to post images. I can however describe the schematic provided with the 400STR carts:
Ahead of the damper is a flat piece of copper configured in an "L" shape, this is the stylus "yolk" and determines the orientation of the cantilever The portion parallel to the cantilever is embedded in the stylus holder. As typical, the cantilever extends loosely through the plastic holder, secured to the damper and then the damper to the yolk. There is a magnet imbedded in the holder. At the end of the cantilever proximal to the coils is a flat slug approximately 0.5mm diameter which interacts with the pole pieces.
The generator system is described as "a combination of induction poles. These poles are respectively Right Channel, Left Channel, Earth Ground and Neutral Ground used to avoid spurious crosstalk".
The schematic supplied with the 400STR is identical to the one illustrated on the fourth page of the above TTN download, framed in an amber background and labeled:
"CONSTRUCTION, Acutex tri-induced magnetic cartridge".
It should be pointed out that on the following page the orientation of the coils are vertical rather than horizontal, for this difference I have no explanation but until further information is provided will rest with the previous "Acutex tri-induced magnetic cartridge".
Not sure this satisfies your curiosity but it's the best info I can provide.
(Edit): Looking a little closer, it seems both the 300 and 400 series are three, not two, not four coil systems. As described by Acutex, "Any excitation of the third coil cancels any spurious crosstalk---prevents any crosstalk from the right channel to be transmitted to the left and vice versa".
Peace,
Peace,
I’m not following, or seeing this “3 pole” design. I count 4 coils in both the 300 and 400 series carts.
Indicated by red dots:
300 series:
400 series:
Regards, Wolfie:
Quote:
"X is the armature for the right channel".
"Y is the armature for the left channel".
"Z is the third armature in the plane of the cantilever".
I believe you're correct. With the 3xx carts, four coils, four pole pieces but three armatures, each of which serves as a magnetic pole.Therefore, "tri-pole". The renderings do clarify this. Focused on the description, insufficient attention was given to the schematics. Thanks for pointing it out.
There seems to be a single induced magnetic pole in the 4xx series. I'll speculate crosstalk reduction is accomplished by reversing current in the second set of coils a' la Ampere. Any thoughts?
Peace,
There aren’t 3 armatures. There is only 1 armature. I double checked the original and my rebuilt under 10x and 25x loupes. The armature is a 1 piece stamped soft iron armature. The Mickey Mouse ears are the same piece as the tube in which the cantilever is mounted. This is true for the 300 II and 300 III Series.
Below, the armature is shown in red. (The magnetic source is shown in pink.) It is made from a single piece of stamped iron. In yellow I show it’s movement from the cantilever. The ears and the forward tube are magnetized from the single permanent magnet. The pole pieces are reading the same movement, just from a forward tube and rear ears. No magic here. The armature moves as one piece since it is one piece, as the cantilever moves. There is no “cancellation” happening here. Just reading a “see-saw” movement fore and aft from the forward tube to the aft ears. Just like an AT cartridge.
Here is my 310 II. I had the stylus rebuilt. The damper ring was replaced using an AT damper ring. The aluminum cantilever was snipped at the armature, and a boron rod inserted into it with a nude MR tip. It sounds really good! But alas, no magic going on here. This tracks at 1.3 grams.
