Piezo-Azden-Acutex Thread
Regards, Wolfie:
The discussion has improved my appreciation of the tri-pole feature, I hope it has been beneficial to others. Regarding your most recent post, you might reexamine the definition of "armature". I count three. How they are fashioned is, in this example, irrelevant to their function.
Quote (Acutex):
"X is the armature for the right channel".
"Y is the armature for the left channel".
"Z is the third armature in the plane of the cantilever".
Wolfie, post 687. You wrote:
"(the) Tripole is merely a different version or incarnation of the AT V magnet design. There is no difference."--- . Different but not different ?
"The Acutex uses a single-piece metal sleeve with 2 ears. The ears work identically to AT’s V magnets, and so does the metal sleeve.--- "poles read the exact same movements as AT’s 4 poles. ---"Identical---No difference." Although their motions are the same, a wind turbine's function differs from that of a fan. Though their movements are the same, a Chevy Vega is not identical to a Tesla.
First Principles methodology is based on fundamental fact. AT forwarded a similar argument in their suit against Acutex. The Court hearing the case disagreed. Distinguishing function from form is important.
Your posts promote thought. I'm looking forward to the next.
Peace,
(edit) BTW, I appreciate the upgrades to your rebuilt Acutex 310.
Different implementations of similar designs can have vastly different sounds. The AT "vector aligned" technology is not the same as the Acutex "Tri-pole". The AT is a moving magnet design and the Acutex is an induced magnet design. The fact that the inducing elements are mounted in a "V" configuration is meaningless. In the AT's case, the inducing elements are magnets - two of them. In the case of the Acutex "Tri-pole", the inducing elements are made of iron (three of them). Hence the term "Tri". The court's decision was correct (apparently someone did their homework on the subject). Not to mention the differences in coil design. Both the AT and Acutex are interesting and unique designs. However, they are not even close in design implementation and sound very different.
BTW, replacing the stylus of a Tri-pole cartridge with a stylus that is missing the third pole piece element results in a completely different sound. I found that the Eagle PS 750SX Shibata replacement stylus sounds best to my ears. I have not tried going the retip route - yet. The Acutex bricks are fun cartridges to experiment with. The Acutex Tripole "Bricks" were very popular and sold under many different brand names (Piezo, Akai, Kenwood, Eagle, and probably several others) all manufactured by Nippon Azden.
The designs are close enough though that the aftermarket manufacturers use the same magnet assemblies that were copied from Audio-Technica designs when producing aftermarket styli for both moving magnet A-T and moving iron Acutex, Azden, Piezo, Spectrum etc. The results aren’t quite as good as separation is low (but adequate 20dB) in every version I’ve tested. The best moving iron originals and Azden-made aftermarket styli reach 30dB. This is speaking only for the bricks.
Depends on what AM stylus you get. there are ones that look just like the at cantilever and its mini V rod ears. those do not have the ferrous sleeve on the cantilever( that also acts as a dampening mechanism) . So that are not the same in that respect and that ruins the separation .
Athanasios
Many times hair-splitting is the sign of a point of view with nowhere to go….
Without regurgitating marketing hype, please explain how you get 3 armatures from 1 piece of metal. (By definition, a single-piece armature is, well, 1 armature!) How a single armature is fashioned means everything, actually. There are no separate movements to the single armature piece. The entire one-piece armature moves with/from the cantilever movement.
You really don’t know the difference? Perhaps I should have said “different looking” incarnation or version of the same thing. Looks can be very deceiving to those who lack understanding of basic principals of operation. I have several skillets that look different; they all perform the same function.
This demonstrates lack of understanding of the basic underlying principles, but does demonstrate very good skills of hair-splitting:
Audio Technica demonstrated extremely well how the Acutex principal of operation was identical.
So, let’s start by you showing us how you get 3 separate armatures from one single soft iron armature. Don’t regurgitate the marketing hype. I’m up for a good lesson in electromechanics! (Spoiler alert: I’ve already done the research.)
Who did that? If you’re referring to me, you didn’t read what I wrote; you jumped to your own conclusion.
This is what I wrote:
The aluminum cantilever was snipped at the armature, and a boron rod inserted into it with a nude MR tip. It sounds really good! But alas, no magic going on here. This tracks at 1.3 grams
This is where the hollow aluminum cantilever was snipped, smoothed, and the boron rod was inserted and secured into the cantilever, dotted yellow line:
Here is a 1-piece ADC armature. It is a tube, but it could have any shape desirable. (That’s the beauty of induced magnetism: The armature can have any shape you can form soft iron into!) As long as it’s 1 piece, it’s a single armature. Yellow lines designate the 1-piece soft iron armature:
Here is the ADC body with 4 pole pieces. Each pole is shown by a yellow line. The 1-piece armature vibrates between these 4 individual pole pieces. (Each pole piece has its own coil.)
By the definition previously given for the Acutex, this one-piece ADC armature is now 4 “armatures”, because there are 4 poles reading the single armature. Makes just as much (non-) sense as the explanation saying the Acutex 1-piece armature is actually 3 armatures.
Regards, Wolfie:
You wrote: "Without regurgitating marketing hype, please explain how you get 3 armatures from 1 piece of metal?"
-Answering your question is like explaining why a 4 valve/cyl twin cam v8 engine doesn't need eight crankshafts and 32 cams.
Another: "I have several skillets that look different; they all perform the same function."
-Abe Lincoln asked the question: "If you call the tail on a dog a leg, how many legs does a dog have? Answer: "Four. No matter what you call it, a leg is still a leg." Back to the discrepancy between function & form, they're still coils & armatures.
"Looks can be very deceiving to those who lack understanding of basic principals of operation."
- Couldn't have said it better myself.
Again: "Audio Technica demonstrated extremely well how the Acutex principal of operation was identical."
- AT lost their case. Think about it.
"The armature moves as one piece since it is one piece, as the cantilever moves. There is no “cancellation” happening here."
- While on the subject ( and thanks for providing the illustrations), if you'll look at the relation of poles to pole pieces you MAY observe the poles distal from the stylus are behind the pole pieces, the third, "Z", proximate to the stylus lays beneath the pole pieces. As the (Acutex terminology) armature "X" approaches the right channel pole piece, the armature "Z" moves away from the corresponding pole piece in the second set of coils, or to the left as the rear poles move to the right & vice versa. They are functionally opposed. Scratch your head & check it out, it is so.
Therefore my curiosity as to wether Andre'-Marie Ampere's determination, now defined as Ampere's Force Law, is that currents passing through parallel wires increase magnetism, currents moving in opposite directions diminish magnetic force. I'd hoped you might provide insight as to wether this had bearing on crosstalk cancelation in which Acutex states their carts excel. As you state "there is no cancellation happening here", perhaps a letter to Acutex will encourage them to correct their error.
Anyway,
Peace.
(Edited to remove an unwarranted comment)
So I decided to mount my hardly used 310 III. I’ve never really liked it that much.
It has a kind of “average” sound. It’s a bonded elliptical, and I have nothing against that. But I have many bonded ellipticals on other cartridges that I enjoy more.
I had a good look “under the hood” so to speak, of both the cartridge body and stylus. It’s made completely different from the II series. It (III) has 2 pole pieces shaped like a “V” that read the center shaft of the armature. Just like the ADC carts. Then it has 2 “broken poles”. 2 poles on the top of the body; they connect to 2 poles on the top of the stylus assembly when it’s slid into the body. The magnetic flux is carried from the permanent magnet into the stylus armature by an “L” shaped piece with a donut that encircles the stylus cantilever. (Called a “yoke” by Acutex literature.) So again you have 4 poles reading the cantilever; 2 in a 90 degree “V” that read the armature axial tube, and 2 that read further away from the axial tube. It’s basically a mirror image of the II series armature.
But the suspension on the III is totally different. It’s suspended in the same way as the ADC and PSX carts. Tube through a donut.
So to me, no magic here at all. That’s why I elected to rebuild the 310 II stylus. Sounds better than the III series. By a lot.
Someone asked about the aftermarket stylus for the 300 II series. Here is a pic of the stylus sold by Pfanstiehl, Swiss made. Only 2 magnets. Made exactly identical to the ones made for AT carts:
Blewpernt:
Right, and I haven’t taken mine apart. Be careful, those magnets pretty much fall right off if you touch them. Anyway, I have AT95E styli built just like that and there is a third magnet inside the rear of the cantilever. Not saying it makes an AT95E a tripole, but if this stylus were built the same way, it could make the Acutex stylus in the Acutex body work like a tripole—sort of ????
I was shocked to find the third magnet in an AT95E stylus. Why would it be there?
BTW, a while back you commented that the Stanton 500 can sound “sublime!” I’ll always remember that. So it’s your fault that I clung on to my cart body, tried different styli, and now keep it among my top 10 carts. It was destined for the dust bin.. A simple cart, but a good one!
If the AT carts use an iron alloy sleeve that secures the cantilever into the grip assembly, and is clamped by the set screw, that iron sleeve will get magnetized by the 2 “V” magnets set in plastic on the cantilever.
Im going to check to see if mine have that iron sleeve. A thin aluminum tube can’t very well be secured by a grub or set screw. It could be a plastic tube, though.
The TRX were the highest order embodiment, or version of the Tripole design.
But as I’ve shown and discussed before, the Tripole is merely a different version or incarnation of the AT V magnet design. There is no difference. The Acutex just moved 2 of the 4 AT poles forward of the magnets. There is no magic.
The AT 4 poles, 2 each side of a V magnet:
The AT V magnets:
Acutex. The red arrows point to the poles placed where the AT poles are. The black arrows point to the 2 poles moved forward. The Acutex uses a single-piece metal sleeve with 2 ears. The ears work identically to AT’s V magnets, and so does the metal sleeve. The sleeve is read by the 2 poles moved forward from AT’s original position. All 4 Acutex poles read the exact same movements as AT’s 4 poles. No magic. No difference.
The third pole on the acutex cantilever works in the z axis to cancel crostalk between the left and right channel. Does the AT V have a similar setup ?
Here is a generic aftermarket replacement stylus( on the left) that is missing the third pole Iron sleeve on the cantilver. These usually sound inferior to the versions with the third pole on the cantilever itself. The other fitted to an Akai PC-100 has the third iron sleeve on the cantilever. It does work even on the after market replacements at enhancing left - right separation. Downforce settings is critical with this brick bodied tripole also...you have to fine tune it by ear.
Did you get the Eagle stylus from England by any chance ? If so.. I hope they sound good :)
That's not a 'tri-pole' stylus. There are no magnets attached to the cantilever on the brick bodied Acutex/Piezo/ Eagle/Akai Tri-poles. There is a single large barrel magnet in the body that the round barrel aperture clamps on to. There is usually a metal lining inside that stylus barrel , presumably to induce magnestism in the three iron poles that surround the cantilever in the x,y,z plane. Some Hitachi cartridges may also use this stylus shape , but i'm not sure if Hitachi hd their own badged tripole made by Azden. I think that stylus is found with the Hitachi dst-103 label...and the cartridge was called the Hitachi MT-103 or something, so check carefully before buying. .
melofelo:
I very clearly stated that about the Pfanstiehl stylus.
I stated:
But this evening I’ll be converting that magnetic stylus into a true “Tri-pole” stylus. (Tripole is a misnomer.) That’ll give me a chance to experiment. If it works, I’ll convert my nude ATN12XE stylus into a stylus that fits and works perfectly (in true “tripole” fashion) on my 310 II body.
There are 4 poles, not 3; one pole for each of the 4 coils in the body. The metal lining of the 300 series II stylus assembly is a shield. No liner in the 300 III LPM series.
So I converted the Pfanstiehl “AT-style” stylus into a TRUE “Tripole” stylus. I’ve been listening to it over the last several days.
The Pfanstiehl stylus I have is a 4x7 bonded elliptical. It sounded rather flat and unremarkable in the Acutex 310 II body. It played, but lacked that extra “pizazz” I hear in the original stylus. The 310 III LPM sounds pretty good, but it also lacks that extra detail and definition I hear from the II “square body”.
The converted Pfanstiehl stylus really sounds good!
Changing it uses those 2 other poles further toward the tip of the cantilever, in addition to 2 poles that read the “Mickey Mouse ears”. They aren’t used with the stock Pfanstiehl stylus. With this modification, I can use the Swiss nude elliptical stylus from my ATN12XE to convert the Pfanstiehl stylus frame into a very nice performing stylus. Fact is, I can use ANY top tier AT stylus to make a top-tier stylus for the Acutex square-body cartridge. An AT VM95-ML would work great!
Like I’ve been saying, when you understand the “Tripole” construction, making effective styli using similar but different methods is pretty easy.
From flat and lifeless, this Pfanstiehl stylus has lots of “pizazz”, extra definition and treble extension. Bass is just bit more punchy, but it’s the “air” in the mids and treble that really comes through now!
My prototype may not look like much, but it completely validates my theory.
The Pfanstiehl stylus:
How it works:
I shaped a very small piece of soft iron that fits between the apex of the “V” magnets. A small spot of super glue holds it in place. The magnetism at the apex of the 2 magnet rods that form the “V” impart their magnetism into the small piece I added. The piece I added is shaped with a point where it fits between the magnets, presenting a face for each magnet to send magnetic flux into it.
I used the tip of a hot soldering pencil to remove the plastic between the magnets. The iron piece I added fits flush to the cantilever and into the the space where the small magnet rods are mounted.
When mounted, the piece I added is an induced magnet. It vibrates with the cantilever over the “Tripole” poles, with the combined magnetic force of both magnets.
The piece I added, outlined in red:
The flow of magnetic flux into the added piece, that produces a voltage into the “Tripole.”
Now to take the “theory” to the next level:
Convert a common AT10/11/12 to a “Tripole” Acutex-style cartridge. I have 4 of these AT bodies, so sacrificing 1 in the interest of “science” is no big deal.
Just have to move the 2 forward poles a little more forward, and convert the magnetic stylus:
file.php
Move them along the red lines to the position shown in yellow:
file.php
