Why?
Why try anything new? Still using your 2005 Nokia phone? Why not?
Anyone else done this before?
Because:
The Pfanstiehl stylus I modified (I made yet another modification, cutting the iron bit I added in half) sounds completely different than it did stock, out of the box. In fact, it sounds better than the NOS 310 II stylus which is a bonded 2x7 elliptical.
And: Original Acutex styli are getting scarce.
And: AT styli for the VM95 are available in some great flavors, at reasonable prices (and others—I just need the cantilever).
And: I can still buy the Pfanstiehl stylus frames.
And: I want to see (hear for myself) if modifying one of the old AT so-so sounding carts improves it’s sound, since I have identical cartridges to compare to.
And: I developed a new type of pole/coil to try out, first in an old Stanton 500, then in an old AT 2-coil cartridge. And yes, it’s new; I’ve looked, and no one has done this before.
The new coil design takes up less space, uses less wire to achieve the same inductance. In the Stanton 500, where high frequencies tend to roll off, I’ve found that with my coils the high frequencies are greatly extended. It has a different, but very pleasing sound.
Inside the old Stanton 500. The coils are 500 mH each, hence the name “500.” I used the wire on these bobbin-wound coils to wind my new coils. I only had to use a little over 1/2 the wire to achieve the same 500 mH.
Because:
add a review
