Piezo-Azden-Acutex Thread
If my memory serves, the Acutex 315 and 320 stylus can interchange. I believe the correct stylus for your 315 is the yellow Pfanstiehl/EVG 707-DE in order to keep the tripole intact. This is what I have for a backup for my 320 after reading the various threads.
The Piezo YM-308 and the Acutex M310 are the same according to my notes. The answers you seek are buried in this thread and a few others or just ask OP directly if he doesn't reply here. You can just try it but I think there are issues with the interchange such that it will not give you the highest quality sound, much like the black vs yellow stylus on your 315.
IDK if I am in the right thread, but just got a technics sl-1500, which included this Acutex 207 stylus and cart. Is it worth keeping? I currently have a stanton 500II with a nude elliptical that i like. Thoughts? Just curious. No idea how much use is on the current sylus.
I have an Acutex 315 that I got (broken) and put the EVG black elliptical stylus on and it sounds great, so much that that I've become dedicated to the search for something higher end in replacement stylus. I just bought this Azden 308Q which is apparently some kind of microline/ridge cartridge. The other Azden 308s (same company as Piezo that made these tri-poles) are similar to Piezo, Acutex at 4mv output and improved frequency response as you move up the cost ladder. This thing is different at 2.5 mv output and some crazy frequency response range - any guesses on what will happen if I put this stylus on the 315 body, perhaps something close to the original STR stylus or better to leave it on the Azden?
Azden
YM-308 Q
add a review
Type
Moving Magnet
Output Voltage
2.5 mV
Freq Response
10Hz - 60kHz
All the different models and name brands are interchangeable in the series 1 bricks like in your picture . There is a different body style brick that uses a different stylus holder.
The difference in cost was basically the stylus. The lower end just had a conical then it went up to basic elliptical then up to the STR, or their version of a shibata that I personally find to be a step above most Shibata cuts. So all are interchangeable and the output and frequency response depends on the stylus as all bodies are electrical the same.
Athanasios
That is the lower end non Tri-Pole LPM( lowest possible mass) cart series. the 3xx series has the Tri-Pole design.
I have not heard the 2xx series but give it a listen and see how it sounds. Also a hard to find replacement like the LPM 3xx series.
I think I have seen a few NOS on the bay . Id keep it for a spare.
Athanasios
Greetings fellow Acutexans! I bought a 320 LPM cart a while ago, without a working stylus. Then finally found a stylus, a supposedly NOS 315 (looks brand new, and I have no reason to not believe the seller).
It arrived a couple of days ago, and I was mounting it up and doing a quick alignment, expecting a cinemascope-wide soundstage... but no... instead I am getting a very boxed in, almost mono sound... Something is wrong, but what? I measured crosstalk with a test record and it was hardly 10dB difference for both channels, i.e. lots of bleeding. The cart is also microphonic as hell, acting like a small speaker filling the room with sounds.
What could be wrong? Cartridge or stylus? I have tried two headshells, a lighter and a heavier (both verified as working with other carts). I also tried adjusting azimuth, but to no avail. The headshell cables are wired correctly, I have double and triple checked... I saw mentioned in other threads about the microphonic part and solving it with blutak or similar to make sure the stylus sits firmly in the cart, however it looks to sit tight in mine, not loose at all.
On another note, I saw an old NEC P305 TT in an online auction and noticed the cart looked very much like an Acutex long-nose. Couldn't verify from the pictures, though, but googling led me to this LP Gear stylus: https://www.lpgear.com/product/NECSP305E.html
Could that be a real substitute for the long-noses, or just another aftermarket not actually working? (I won't buy it anyway, since it costs too much across the pond, but still curious.)
Are you sure the body is from the 3xx series and not the 2xx series? We need a picture of the nose of the cart showing the mounting point of the stylus assembly . There should be a magnet in the nose. If not its a 2xx series and won't sound right.
I don't think its the same, I bought a similar looking stylus years ago and it doesn't fit .
Athanasios
Thanks for the reply! Not 100% sure it is a 3XX body, but... Do the 2XX bodies have "LPM" on their sides too? In any case, I will take pictures tonight and post for the experts to decide. :)
EDIT: I forgot, it has golden pins, which led me to believe it really is a 320...
Looks like maybe a piece is missing in there...?
OK, here.
EDIT: one more
Thanks @wualta and @Nashou66 for confirming! Another pic here. Is something just peeking out on the right side or missing from the left side?
I suspect it's part of the pole piece that the black plastic [potting?] would normally cover.
The microphony is something I've experienced only once, and potting the insides with some epoxy cured that, fortunately. I suspect something (coil, coil+core) has come loose inside the LPM, but its interior isn't easily accessible. Hoping someone has disassembled one and can help.
