Piezo-Azden-Acutex Thread
Okay, enough with the sprained metaphors. Now we come to the part of the program we call "Don't Buy This One".
Unfortunately, I can't find a picture of this 707-DE stylus. It's gray and doesn't have a stylus guard and doesn't have an identifying sticker or label. The stylus feels nice and compliant; the diamond and mount-- in fact, everything-- all looks just like the yella 707-DE. So what's the problem?
It bounces. I couldn't believe it myself. I swapped the gray for the yella and tried to play an old CD-4 disc with a minor pinch warp which didn't faze the yella stylus. Imagine my surprise when, all-over-sodden, the sound faded rapidly in and out and the pitch got all wobbly. I thought something had gone wrong with the turntable. Then I saw what the tonearm was doing. Apparently this suspension (the elastomer disc at the base of the cantilever) isn't made of butyl rubber, because it has little to no damping ability, which may go some way toward explaining the very bright sound. VTF was 1.5g for both styli. Same turntable, same cartridge body.
So I'm going to say don't buy the gray 707-DE. Tomorrow I'll drive over to where my bouncy example is and take a photo. I would tell you where I got this one, but I honestly can't remember.
I was watching its Jehosaphat, and it was certainly jumpin'. The weirdest thing was what it did to the audio. I was almost certain one of my preamp's selector switches had gone dirty.
Was it this one wualta?
I realize how frightening the experience was ;) but have you tried a higher VTF? 1.75g or 2.0g ?
I've looked at that photo before. It appears not to be an IM. Note the absence of an armature at the base of the cantilever. These are visible on both the original styli and the yellow 707-DE. It would be informative to have a view of the inside of the grip to see whether there was a slug in there.
Also, it appears to be black. Gray ones were original equipment in some applications like the Acutex M307IIE but they had an ID label.
John
Those of you running the LPM longnose series, how long did it take for stylus break-in?
I took a hiatus from the vinyl hobby for about a year, and over the past few weeks re-acquainted myself with my carts. I remember I had benched my NOS 315 stylus thinking was damaged -- it appeared to like a higher effective mass than its LPM designation let on, leading me to believe that its suspension was dried up. Reading this thread (and the previous dedicated Acutex LPM one), it seemed others had the same experience, so I remounted it in my heaviest shell and have given it a spin.
Nice clarity in the highs and mids, but lower registers need work. Kick drum thoomps come out more like plods. Soundstage is shallow, but the stereo image takes on this interesting 3D quality that is hard to describe. I'd say it seems to arrange everyone on the same plane but they are distinct in their areas.
I swapped in a NOS 312 stylus and it appears to show the same general signature. I'm hoping that the 315 stylus improves as the hours are tacked on (I'd say I've clocked maybe 5 hours on the thing). Really just need it to open up on the lower end and get some depth in the stage.
boreas and jkilla: Yeah, the bouncy one's not labeled, has no flippy stylus guard (and no place to attach one) and is an old-hippie-beard light gray.
But what's this one andydeals has labeled a 4707-DE?
Yeah, definattley moving-magnet. Does that mean Acutex/Azden at some point abandoned the IM tripole, or were both designs available side by side ? I'm thinking of that Spectrum stylus from earlier in the thread and also the LPM 312 v. 412. And can the Pfanstiehl index differentiate between the 707-DE that's IM and the one that's MM? Doubt it.
jkilla: No, didn't try higher VTF, which would have banged the cartridge on the record as it bounced.
Yeah, definattley moving-magnet. does that mean Acutex/Azden at some point abandoned the IM tripole, or were both designs available side by side ? I'm thinking of that Spectrum stylus from earlier in the thread and also the LPM 312 v. 412. And can the Pfanstiehl index differentiate between the 707-DE that's IM and the one that's MM?
I would go as far to say the aftermarket producers were too cheap or didn't have the means to make stylus with the IM
But, despite adhering to the Pfanstiehl numbering system for OEM styli, the yellow 707-DE is aftermarket and it's both tri-pole and IM.
It appears that there were three, maybe four, iterations of these cartridges. There is the IM tri-pole like the 300 series LPMs, the MM tri-poles like the 400 series LPMs and the IM non tri-pole like the 200 series LPMs. The fourth type might be inferred from the stylus that Walt has. IT's definitely an MM and appears to lack the "Z Pole" armature of the tri-poles.
John
Exactly. I've noticed that the leading-4 numbering guarantees aftermarket, but that even styli without the preceding 4 may still be aftermarket. Which is just sad.
boreas said:
... The fourth type might be inferred from the stylus that Walt has. IT's definitely an MM and appears to lack the "Z Pole" armature of the tri-poles.
To clarify: Except for the LPM 412, I don't have any MM Acutexans. I have three 4707-DEs-- two yellas and one gray-- and they're all MI tripoles. Just happened to spot that impostor.
John
Interesting theory, I wonder if it translates into some non-obvious series like 2xx, 1xx or something.
I also spotted this one too wualt, also from andydeals
http://www.ebay.com/itm/EVG-PM2891D...S-707-DE-/371129430958?_trksid=p2054897.l5675
Late to the party, but love this thread. I have a Piezo YM something or other, and like what I hear from it. I'll be back here when it's time to buy some replacement stylii.
I have an M210II E, an M312III STR and a 412 STR. The 412 actually may not be broken in yet but the other two most certainly are. I don't recall any dramatic change as they broke in.
I'd be interested to learn what VTF you've settled on. You mention starting out at a low VTF consistent with published compliance specs and then raising it. Could you tell us where you started and where you are now? Most of us end up at or a little above 2g with these, both for the 312 and 315.
At some point Acutex (Piezo) revised the specs for the 300 series LPMs. In the case of the 312 they went from a compliance of 32 x 10-6 to 24 x 10-6. For the 315 it went from 38 x -6 to 36 x 10-6. Recommended VTF was changed from 1.2 - 2.5g for the 312 and from 0.4 - 0.9 for the 315 to 1.5 to 2.3g for both.
So, after revision, the recommendations for VTF seem to jibe more closely with reality but are still seemingly at odds with published compliance. I've learned not to worry about that. :)
John
jkilla said:
I also spotted this one too wualt, also from andydeals...
Yep, that one's legit, got the ears and everything. We're just going to have to be careful when we buy these things. Looks like the Pfanstiehl numbers aren't going to help us here.
Maybe.......... maybe the 707-DE is always going to be an IM and the 4707-DE is always going to be MM? :dunno: The EVG, though Anderson says it crosses to the 4707-DE would then actually cross to the 707-DE since it, like the EVG, is IM. Very confusing but it keeps ze leetle gray cells busy!
John
John
I am aware of the VTF shift towards heavier from the beginning, so I've always ran it at 2g+. I'll see if giving it a few hours at max 2.3g will make any difference. Crossing my fingers that it'll sort itself out as the suspension gets worked. What's there is lovely, it's just missing some bump.
a uk ebay search brings up some generics for the tri-pole bricks..no affiliation to seller btw this link is just an example of a search for a hitachi ds-st103
Some may or may not have the magnetic shielding in the barrel that fits over the magnet.
http://www.ebay.co.uk/itm/Stylus-for-Record-Player-DSC685-Hitachi-DS-ST103-Stylus-/261558690439?pt=UK_AudioTVElectronics_HomeAudioHiFi_Turntables&hash=item3ce61ce287
Piezo ym 308 version:
http://www.ebay.co.uk/itm/NOS-Piezo-YM308-Stylus-/131277859923?pt=Turntable_Parts_Accessories&hash=item1e90c52c53
Thanks, melo. I certainly could be mistaken but I think the one advertized as "NOS Piezo YM-308" is aftermarket. I've not seen any originals marked "STEREO", only aftermarket (and not all of those). The originals I've seen all have the model number of the cartridge they belong to printed on the label. Certainly those for the YM-308 are so marked, Also, at least in my experience, the armatures on the original styli are fixed to the cantilever by a bright blue adhesive, visible with the naked eye.
The stylus in this listing looks just like the EVG stylus pictured earlier in this thread. I suspect that it and the stylus you linked to, both in fact, are the same. Still, I think they're probably very decent and worth the prices being asked.
John
