dusttones
Member
I'm just diving into restoring this 8282 I picked up a long time ago. I have the belt and rubber pulley kit from WJOE in hand. Before I tore it down, it did not play/ff/rewind. After digging into the forum, it sounds like I may have a idler clutch to address. But the issue at hand is belt #5. Instructions indicate to remove the idler assembly and replace. I've removed the e-clip, but the assembly will not come out. Any ideas would be appreciated.
