Pioneer CTF 1000
out of curiosity (and having restored a CT-F1000 recently)
What do you need it for?
There's a lot to go wrong in those mofos, 'specially at this late date!
Well I just got this beast and looks like I got a dud cause the play stops after a few seconds, counter does not work and FF and RE are not working. I thought as long as it is a dud there is no harm in going in there to try to fix it. That is why I needed a service manual even though I have never done anything like this. :scratch2:
I will be doing this exact same thing with my 1000 so I will e watching this thread closely and a big Thank You go's out to santashooter for his words of encouragement
Thanks. I just ordered CT-F1000: Belt Kit WITH Rubber Pulley Kit. It is kinda dirty inside so I will be blowing off the dirt in there. I will post once the kit is installed. :thmbsp:
You will also need to be aware of the reel sensor (the black thing with the wires that come out of it) and make sure it works right.
Replace the belts and pulleys first, they are usually the main culprit. Then think about replacing the tape presence switch if that doesn't fix the problem. More than likely it's the belt(s) to the tape counter. It's lots of fun replacing the belts and pulleys. :no::D
have only been inside such a deck once, not much worse than replacing the capstanbelt on a Hitachi D980 - well, :wtf:
some has tried it before, so what's the problem ?
it is fairly easy, as long as you take care of the circlips (or the "jesus-clips", because you go "Oh Jesus" when one gets airborn) and you follow the instructions - it took me about an hour to do it...
did that hour including time to search for the c-clips ? :D
I covered the C-clip with the palm of my hand, so it didn't fly to far - so yes, but otherwise take 2 hours of searching on the floor into the calculations :beatnik:
if and when i'm feeling extreemely bored - and has to throw something in the dumpster - i sometimes find myself into taking things completely apart, thereby collecting all those small "hard to find" thingies :yes:
You'll never know when you need a thing from that collection, quite often sooner than expected.:scratch2:
