jozeppy26
Boy oh boy was this far more of a project than I had anticipated! I had to add small spacers between the crossover and terminal plate to allow more room for the nut and washer to tighten against the soldering washer. All in all I’m super pleased. The original binding post screws had a ton of corrosion (both on the screw and locking key washer). Now the input connections are clean and the crossover is completely clear of corrosion and weak connections!! Woohoo. Plus, these new binding posts are so much prettier.
