cockroach
Member
Since I need to order some parts from Mouser anyway, I figured it might be time to finally order the things needed to recap my SA-800 and I would appreciate a bit of feedback.
I tried to find caps that were as close to the original specs as I could find (in capacity / voltage as well as physical dimensions) but in some I failed and used slightly higher values instead. Also, I noticed that people usually seem to order Nichicon capacitors but in some cases I couldn't find anything matching the parts I need so I used parts by someone else – does it matter?
As for the transistors, I just copied those types from other threads where similar replacements were made. I have no idea which parts of transistor specs are relevant (other than the NPN vs. PNP thing) so feel free to tell me if I'm doing something stupid. Also, I'm not sure I should mess with the transistors at all. Does it make sense to replace them proactively?
So anyway, here's the list of parts that I came up with:
Misc – Capacitors
A bit of a rocky start. These capacitors are huge and sit in special holders, I'll probably need some sort of padding construction to install any of the tiny replacement caps that I could find.
In my amp, C3, 4, 7 and 8 differ significantly from what's in the manual. In the case of C3 and C4 it might not matter, but C7 and C8 are quite a bit smaller than specified. Should I go with the large (30uF, 6V) from the manual or the small (7uF, 25V) currently installed? Or order both, and see what happens?
I think I'll leave Q11~14 alone for now.
Misc – Capacitors
- C33 (C52-088-B, 4700uF, 50V, 40mm / 6mm): ALP22A472DD100 (100V) or UVR1J472MRD (63V, 22mm)
- C34 (C52-088-B, 4700uF, 50V, 40mm / 6mm): ALP22A472DD100 (100V) or UVR1J472MRD (63V, 22mm)
- C35 (ACH-001-B, 1000uF, 63V, 31mm / 4.8mm): LKG1K152MESBBK (80V) or UVR2A102MRD6 (100V, 20mm)
- C1 (CSSA 010X 25: 1uF, 25V, d:5mm, pins:5mm): UFG1H010MDM (50V)
- C2 (CSSA 010X 25: 1uF, 25V, d:5mm, pins:5mm): UFG1H010MDM (50V)
- C3 (CEA 470P 25: 47uF, 25V, 85°C, d:8mm, pins:6mm): UKZ1H470MPM1TD (50V)
- C4 (CEA 470P 25: 47uF, 25V, 85°C, d:8mm, pins:6mm): UKZ1H470MPM1TD (50V)
- C5 (CEA 100P 25: 10uF, 25V, d:7mm, pins:6mm): UFG1H100MDM (50V, 5mm)
- C6 (CEA 100P 25: 10uF, 25V, d:7mm, pins:6mm): UFG1H100MDM (50V, 5mm)
- C15 (CEA 101P 35: 100uF, 35V, 85°C, d:18mm, pins:10mm): UKZ2A101MHM1TN (100V, 16mm) or UKZ1H101MHM (50V, 12.5mmV)
- Q1 (Transistor 2SC1000-BL): KSC1845FTA
- Q2 (Transistor 2SC1000-BL): KSC1845FTA
- Q3 (Transistor 2SC1000-BL, GR): KSC1845FTA
- Q4 (Transistor 2SC1000-BL, GR): KSC1845FTA
- Q5 (Transistor 2SC1000-BL, GR): KSC1845FTA
- Q6 (Transistor 2SC1000-BL, GR): KSC1845FTA
- C3 (CEA 300P 6: 30uF, 6V (current: 33uF, 10V), d:6mm, pins:5mm): UFG1E330MEM1TD (33uF, 25V)
- C4 (CEA 300P 6: 30uF, 6V (current: 33uF, 10V), d:6mm, pins:5mm): UFG1E330MEM1TD (33uF, 25V)
- C7 (
CEA 300P 6: 30uF, 6V4.7uF, 25V, d:5mm, pins:2mm): UFG1H4R7MDM (50V) - C8 (
CEA 300P 6: 30uF, 6V4.7uF, 25V, d:5mm, pins:2mm): UFG1H4R7MDM (50V) - C11 (CEA 100P 25: 10uF, 25V, d:7mm, pins:6mm): UKZ2A100MPM1TD (10uF, 100V) or UFG1H100MDM (10uF, 50V, 5mm/2mm)
- C12 (CEA 100P 25: 10uF, 25V, d:7mm, pins:6mm): UKZ2A100MPM1TD (10uF, 100V) or UFG1H100MDM (10uF, 50V, 5mm/2mm)
- C13 (CEA 100P 25: 10uF, 25V, d:7mm, pins:6mm): UKZ2A100MPM1TD (10uF, 100V) or UFG1H100MDM (10uF, 50V, 5mm/2mm)
- C14 (CEA 100P 25: 10uF, 25V, d:7mm, pins:6mm): UKZ2A100MPM1TD (10uF, 100V) or UFG1H100MDM (10uF, 50V, 5mm/2mm)
- C15 (CEA 500P 25: 220uF, 35V, d:13mm, pins:10mm): UFG1H331MHM (330uF, 50V)
- Q3 (Transistor 2SC458LG): KSC1815YTA
- Q4 (Transistor 2SC458LG): KSC1815YTA
- Q5 (Transistor 2SC458LG): KSC1815YTA
- Q6 (Transistor 2SC458LG): KSC1815YTA
- C5 (CEA 010P 25: 1uF, 25V, d:5mm, pins:5mm): UFG1H010MDM (50V) or MKS2B041001C00JSSD (50V, film)
- C6 (CEA 010P 25: 1uF, 25V, d:5mm, pins:5mm): UFG1H010MDM (50V) or MKS2B041001C00JSSD (50V, film)
- C11 (CEA 100P 16: 10uF, 16V, d:6mm, pins:5mm): UKZ2A100MPM1TD (10uF, 100V) or UFG1H100MDM (10uF, 50V, 5mm/2mm)
- C12 (CEA 100P 16: 10uF, 16V, d:6mm, pins:5mm): UKZ2A100MPM1TD (10uF, 100V) or UFG1H100MDM (10uF, 50V, 5mm/2mm)
- C17 (CEA 221P 25: 220uF, 25V, d:13mm, pins:10mm): UKZ1E221MHM
- Q1 (Transistor 2SC870-E or F): KSC1845FTA
- Q2 (Transistor 2SC870-E or F): KSC1845FTA
- C1 (CSSA 010X 25: 1uF, 25V, d:5mm, pins:6mm): UFG1H010MDM (50V)
- C2 (CSSA 010X 25: 1uF, 25V, d:5mm, pins:6mm): UFG1H010MDM (50V)
- C9 (CEA 221P 10: 220uF, 10V, 10mm): UFG1C221MPM1TD (16V)
- C10 (CEA 221P 10: 220uF, 10V, 10mm): UFG1C221MPM1TD (16V)
- C11 (CEA 220P 6: 22uF, 6V (current: 6.3V), 5mm): UKZ2A220MPM (100V) or UFG1E220MDM1TD (25V, pins: 2mm)
- C12 (CEA 220P 6: 22uF, 6V (current: 6.3V), 5mm): UKZ2A220MPM (100V) or UFG1E220MDM1TD (25V, pins: 2mm)
- C13 (CEA 101P 50: 100uF, 50V, 13mm): UKZ1H101MHM
- C14 (CEA 101P 50: 100uF, 50V, 13mm): UKZ1H101MHM
- Q1 (Transistor 2SA572-4B): KSA992FBU
- Q2 (Transistor 2SA572-4B): KSA992FBU
- Q3 (Transistor 2SA572-4B): KSA992FBU
- Q4 (Transistor 2SA572-4B): KSA992FBU
- Q5 (Transistor 2SC627-1): KSC3503DSTU
- Q6 (Transistor 2SC627-1): KSC3503DSTU
- Q7 (Transistor 2SC497-0): KSC2383YTA
- Q8 (Transistor 2SC497-0): KSC2383YTA
- Q9 (Transistor 2SA497-0): KSA1013
- Q10 (Transistor 2SA497-0): KSA1013
Q11 (Transistor 2SC793-Y): MJ21194GQ12 (Transistor 2SC793-Y): MJ21194GQ13 (Transistor 2SC793-Y): MJ21194GQ14 (Transistor 2SC793-Y): MJ21194G
- C3 (CEA 221P 10: 220uF, 10V, d:10mm, pins:6mm): UFG1C221MPM1TD (16V) or UPW1V221MPD (35V)
- C4 (CEA 221P 10: 220uF, 10V, d:10mm, pins:6mm): UFG1C221MPM1TD (16V) or UPW1V221MPD (35V)
- C5 (CEA 101P 16: 100uF, 16V, d:10mm, pins:6mm): UFG1V101MPM (35V) or UPW1J101MPD (63V)
- Q1 (Transistor 2SC983-0): KSC2383YTA
- Q2 (Transistor 2SC983-0): KSC2383YTA
- Q3 (Transistor 2SC945-R): KSC1845FTA
- Q4 (Transistor 2SC945-R): KSC1845FTA
- Q5 (Transistor 2SA572-4): KSA992FBU
- Q6 (Transistor 2SC968-2): KSC2383YTA
- Q7 (Transistor 2SC495P-Y): KSC2690AYS (may not fit), MJE181 or KSD794AYSTU
- C5 (CEA 101P 50: 100uF, 50V, d:13mm, pins:10mm): UPW2A101MHD (100V) or UPW1J101MPD (63V, 10mm/5mm)
- C7 (CEA 221P 35: 220uF, 35V, d:13mm, pins:10mm): UPW1V221MPD (10mm)
- C8 (CEA 331P 25: 330uF, 25V, d:13mm, pins:10mm): UPW1J331MHD1TD (63V)
- Q1 (Transistor 2SD234-0): KSC2073TU
- Q2 (Transistor 2SC373): KSC2383YTA
