Pioneer SA 8500 rebuild
wwiztab
I have an SA 8500 I've had for about two years now. It works and sounds great. Is there any reason to have any work done now to make it perform better or update components or just wait until it needs a repair?
Yes. Many of the Caps have certainly dried out some from the 30+ years of it's life (providing no prior replacement). And there are "some" improved upon components that can keep her singing for many years to come. In addition to a thorough cleaning of all switches, pots and controls, which is invaluable in prolonging the life and making it perform that much better. Just take your time, be methodical in approach and use the knowledge and experience on AK.
Having the SM is a great start. There is no "easy" parts replacement listing. You will need to do some extensive searching here on AK and look for the most recent postings of the caps and such for the 8500. These parts "lists" are updated quite often, as newer parts are identified and become known as superior replacements, so be careful what you compile. Once you have it in order, post it on AK for some of the more experienced people to peruse and make tweaks/suggestions to.
EDIT::: I did a quick search, and didn't turn up too much on this unit. I would clean it up really well, then pick a board and start re-capping it. Power supply board is a decent place to begin usually. Pay CLOSE attention to the orientation of the caps (Neg and pos leads). Power it on after each board has been recapped and make DC offset adjustments and such to ensure that the tolerances stay in range so other boards/components do not get damaged by the possible changes in specs. Do some research and build yourself a Dim Bulb Tester (it's easy) and it will save your ass if something was to go awry.
recap it, then if you want to "go nuts":
phono amp 2sa725, 2sc1313 >> ksa992, ksc1845
control amp 2sa726, 2sc1313 >> ksa992, ksc1845
power amp 2sa726, 2sc1451 > ksa992, KSC3503
protection 2sc945, 2sc1384 >>ksc2383, ksc2690
power supply rebuild/beef up - a bit more than I can do right now.
512-KSA1013YBU to-92L ecb 160v 1a .9w 50mhz 160-320hfe $0.34 (R=60-120, O=100/200, Y=160/320)
512-KSC2383YBU to-92L ecb 160v 1a .9w 50mhz 160-320hfe $0.17
512-KSA940 pnp to-220 bce 150v 1.5a 25w 4mhz 40-140hfe $0.62
512-KSC2073TU npn to-220 bce 150v 1.5a 25w 4mhz 40-140hfe $0.66
512-KSA992FBU (ln)to-92 ecb 120v .05a .5w 100mhz 150-800hfe $0.05 ea
512-KSC1845EBU (ln)to-92 ecb 120v .05a .5w 100mhz 150-800hfe $0.05 ea
512-KSC2690AYS to-126 ecb 120/a160 1.2a 20w 155mhz 35-320hfe $0.40
512-KSC3503Dstu to-126 ecb 300v .1a 1.2/7w 150mhz 40-320hfe $0.28 ea
just to be sure, this is a SA-8500 and not a SA-8500II ??
if you do up a list in the format of:
zzz-999 c1 100uf 50v cea (or ceanl,cssa, csza and so forth)
zzz-999 c2 20uf 65v ceanl
for each of the boards inside
and so forth, I or someone else can quickly get the actual replacement capacitor parts numbers (from mouser) rather quickly - the hard slow part is making that initial list of what's needed from the service manual.
I or mattsd and a few others are getting pretty good at the UPW / UKL / DSF / ECQ capacitor lists..
Here is my recap list for the SA-8500, including the known problem transistors, look it over Mark, and tell me what you think:
Equalizer Amp Assembly (AWF-016-A)
AWF-016-A: C1: 1uF 25v CSSA: 667-ECQ-V1H105JL5 1uF 50v
AWF-016-A: C2: 1uF 25v CSSA: 667-ECQ-V1H105JL5 1uF 50v
AWF-016-A: C7: 330uF 6.8v CEA: 647-UPW1A331MPD 330uF 10v
AWF-016-A: C8: 330uF 6.8v CEA: 647-UPW1A331MPD 330uF 10v
AWF-016-A: C11: 3.3uF 25v CEANL: 647-UKL1H3R3KDDANA 3.3uF 50v
AWF-016-A: C12: 3.3uF 25v CEANL: 647-UKL1H3R3KDDANA 3.3uF 50v
AWF-016-A: C17: 100uF 25v CEA: 647-UPW1E101MED 100uF 25v
AWF-016-A: C18: 220uF 25v CEA: 647-UPW1E221MPD 220uF 25v
Q1: 2SA725: 512-KSA992FBU
Q2: 2SA725: 512-KSA992FBU
Control Amp Assembly (AWG-034-A)
AWG-034-A: C1: .33uF 25v CSSA: 667-ECQ-V1H334JL .33uF 50v
AWG-034-A: C2: .33uF 25v CSSA: 667-ECQ-V1H334JL .33uF 50v
AWG-034-A: C7: 100uF 10v CEA: 647-UPW1A101MDD6 100uF 10v
AWG-034-A: C8: 100uF 10v CEA: 647-UPW1A101MDD6 100uF 10v
AWG-034-A: C13: 2.2uF 25v CSSA: 647-UKL1H2R2KDDANA 2.2uF 50v
AWG-034-A: C14: 2.2uF 25v CSSA: 647-UKL1H2R2KDDANA 2.2uF 50v
AWG-034-A: C15: 4.7uF 25v CSSA: 647-UKL1H4R7KDDANA 4.7uF 50v
AWG-034-A: C16: 4.7uF 25v CSSA: 647-UKL1H4R7KDDANA 4.7uF 50v
AWG-034-A: C23: 4.7uF 25v CEANL: 647-UKL1H4R7KDDANA 4.7uF 50v
AWG-034-A: C24: 4.7uF 25v CEANL: 647-UKL1H4R7KDDANA 4.7uF 50v
AWG-034-A: C25: 10uF 16v CSSA: 647-UKL1C100MDDANA 10uF 16v
AWG-034-A: C26: 10uF 16v CSSA: 647-UKL1C100MDDANA 10uF 16v
AWG-034-A: C29: 100uF 10v CEA: 647-UPW1A101MDD6 100uF 10v
AWG-034-A: C30: 100uF 10v CEA: 647-UPW1A101MDD6 100uF 10v
AWG-034-A: C31: 4.7uF 25v CSSA: 647-UKL1H4R7KDDANA 4.7uF 50v
AWG-034-A: C32: 4.7uF 25v CSSA: 647-UKL1H4R7KDDANA 4.7uF 50v
AWG-034-A: C39: 4.7uF 25v CEANL: 647-UKL1H4R7KDDANA 4.7uF 50v
AWG-034-A: C40: 4.7uF 25v CEANL: 647-UKL1H4R7KDDANA 4.7uF 50v
AWG-034-A: C41: 10uF 16v CSSA: 647-UKL1C100MDDANA 10uF 16v
AWG-034-A: C42: 10uF 16v CSSA: 647-UKL1C100MDDANA 10uF 16v
AWG-034-A: C45: 100uF 10v CEA: 647-UPW1A101MDD6 100uF 10v
AWG-034-A: C46: 100uF 10v CEA: 647-UPW1A101MDD6 100uF 10v
AWG-034-A: C47: 2.2uF 25v CSSA: 647-UKL1H2R2KDDANA 2.2uF 50v
AWG-034-A: C48: 2.2uF 25v CSSA: 647-UKL1H2R2KDDANA 2.2uF 50v
AWG-034-A: C49: 100uF 10v CEA: 647-UPW1A101MDD6 100uF 10v
AWG-034-A: C50: 100uF 10v CEA: 647-UPW1A101MDD6 100uF 10v
AWG-034-A: C51: 100uF 10v CEA: 647-UPW1A101MDD6 100uF 10v
AWG-034-A: C52: 100uF 10v CEA: 647-UPW1A101MDD6 100uF 10v
Power Amp Assembly (AWH-042-0)
AWH-042-0: C1: .47uF 25v CSSA: 667-ECQ-V1H474JL .47uF 50v
AWH-042-0: C2: .47uF 25v CSSA: 667-ECQ-V1H474JL .47uF 50v
AWH-042-0: C3: 33uF 16v CEA: 647-UPW1C330MDD 33uF 16v
AWH-042-0: C4: 33uF 16v CEA: 647-UPW1C330MDD 33uF 16v
AWH-042-0: C9: 220uF 6.8v CEA: 647-UPW1A221MED 220uF 10v
AWH-042-0: C10: 220uF 6.8v CEA: 647-UPW1A221MED 220uF 10v
AWH-042-0: C11: 47uF 50v CEA: 647-UPW1H470MED 47uF 50v
AWH-042-0: C12: 47uF 50v CEA: 647-UPW1H470MED 47uF 50v
Q1: 2SA726: 512-KSA992FBU
Q2: 2SA726: 512-KSA992FBU
Q3: 2SA726: 512-KSA992FBU
Q4: 2SA726: 512-KSA992FBU
Q5: 2SC1451: 512-KSC3503ESTU
Q6: 2SC1451: 512-KSC3503ESTU
Switch Circuit Assembly (AWS-083-D)
AWS-083-D: C6: 220uF 63v CEA: 647-UPW1J221MPD6 220uF 63v
AWS-083-D: C7: 220uF 50v CEA: 647-UPW1H221MPD 220uF 50v
AWS-083-D: C8: 47uF 16v CEA: 647-UPW1C470MDD 47uF 16v
AWS-083-D: C9 220uF 50v CEA: 647-UPW1H221MPD 220uF 50v
AWS-083-D: C11: 220uF 63v CEA: 647-UPW1J221MPD6 220uF 63v
AWS-083-D: C12: 220uF 50v CEA: 647-UPW1H221MPD 220uF 50v
AWS-083-D: C13: 47uF 16v CEA: 647-UPW1C470MDD 47uF 16v
AWS-083-D: C14: 220uF 50v CEA: 647-UPW1H221MPD 220uF 50v
AWS-083-D: C16: .22uF 25v CSSA: 667-ECQ-V1H224JL2 .22uF 50v
AWS-083-D: C17: .22uF 25v CSSA: 667-ECQ-V1H224JL2 .22uF 50v
AWS-083-D: C18: 330uF 6.8v CEA: 647-UPW1A331MPD 330uF 10v
AWS-083-D: C19: 330uF 6.8v CEA: 647-UPW1A331MPD 330uF 10v
AWS-083-D: C20: 100uF 16v CEA: 647-UPW1E101MED 100uF 25v
AWS-083-D: C21: 2.2uF 25v CSSA: 647-UKL1H2R2KDDANA 2.2uF 50v
AWS-083-D: C36: 100uF 25v CEA: 647-UPW1E101MED 100uF 25v
AWS-083-D: C37: 100uF 25v CEA: 647-UPW1E101MED 100uF 25v
AWS-083-D: C38: 1uF 50v CEA: 647-UPW1H010MDD 1uF 50v
AWS-083-D: C39: 1uF 50v CEA: 647-UPW1H010MDD 1uF 50v
AWS-083-D: C40: 10uF 25v CEA: 647-UPW1E100MDD 10uF 25v
AWS-083-D: C41: 10uF 25v CEA: 647-UPW1E100MDD 10uF 25v
BOM List:
667-ECQ-V1H105JL5 | 2
647-UPW1A331MPD | 4
647-UPW1A101MDD6 | 10
647-UPW1E101MED | 4
647-UKL1H3R3KDDANA | 2
647-UPW1E221MPD | 1
667-ECQ-V1H334JL | 2
647-UKL1H2R2KDDANA | 5
647-UKL1H4R7KDDANA | 8
647-UKL1C100MDDANA | 4
667-ECQ-V1H474JL | 2
647-UPW1C330MDD | 2
647-UPW1A221MED | 2
647-UPW1H470MED | 2
647-UPW1H221MPD | 4
647-UPW1J221MPD6 | 2
667-ECQ-V1H224JL2 | 2
647-UPW1C470MDD | 2
647-UPW1H010MDD | 2
647-UPW1E100MDD | 2
512-KSA992FBU | 8
512-KSC3503ESTU | 2
All caps and transistors were confirmed to be in stock at the time of posting.
Trusting you on the originals, the subs look just plain excellent. Thank You :D
edit note:
512-KSC3503ESTU discontinued
512-KSC3503dSTU current
Q5: 2SC1451: 512-KSC3503ESTU becomes Q5: 2SC1451: 512-KSC3503dSTU
Q6: 2SC1451: 512-KSC3503ESTU becomes Q6: 2SC1451: 512-KSC3503dSTU
512-KSC3503ESTU | 2 becomes 512-KSC3503dSTU | 2
About $30.00 parts not including the Main Filter caps (about $5.00 ea) if you get the parts. . Labor probably 3-5 hours at the going rate for your area.
Just tried using Matt's BOM and 9 of 22 of the item queries are not available any longer. It's getting tough to do restorations anymore.
I will post up if I find suitable subs for those NLA.
Assume Nichicon lytics. If you will, post the 9 that are not available (thru Mouser). Maybe then a updated list can be made showings possible Panasonic or others.
