Pioneer SA 9800 Power Supply Board Help
SYK3S
Hi can anyone chime in with a mouser or digikey list of transistors and capacitors to rebuild my pioneer sa 9800 power supply board
thanks in advance
Sykes
Not mine but MTF wrote this in my thread.
Power Supply
awr-194 c2 220uf 80v ceb-axial 220 100 647-TVX2A221MCD
awr-194 c3 220uf 80v ceb-axial 220 100 647-TVX2A221MCD
awr-194 c4 47uf 10v cea 47 10 647-UPW1A470MDD6
awr-194 c7 47uf 63v cea 47 100 647-UPW2A470MPD1TD
awr-194 c8 47uf 63v cea 47 100 647-UPW2A470MPD1TD
awr-194 c9 47uf 63v cea 47 100 647-UPW2A470MPD1TD
awr-194 c10 47uf 63v cea 47 100 647-UPW2A470MPD1TD
awr-194 c13 2.2uf 50v cea 2.2 50 647-UPW1H2R2MDD
awr-194 c14 2.2uf 50v cea 2.2 50 647-UPW1H2R2MDD
awr-194 c15 100uf 35v cea 100 35 647-UPW1V101MPD1TD
awr-194 c16 100uf 35v cea 100 35 647-UPW1V101MPD1TD
awr-194 q1 2sc1735 pwr pass + 100v .5a .8w 512-KSC2690AYS to-126 30 to 300 hfe 130mhz to-92
awr-194 q2 2sc1735 pwr pass - 100v .5a .8w 512-KSC2690AYS to-126 30 to 300 hfe 130mhz to-92
awr-194 q3 2sa733 pwr darl + 50v 0.15a 0.25w 512-KSA1013YBU to-92L 40-700hfe 180mhz to-92
awr-194 q4 2sa904 pwr darl - 90v 0.05a 0.2w 512-KSA1013YBU to-92L 250hfe 150mhz to-92*c
awr-194 q5 2sk34 leave alone, unobtanium
awr-194 q6 2sk34 leave alone, unobtanium
awr-194 q7 2sc1914 fb ampl + 90v 0.05a 0.2w 512-KSC1845FTA (ln)to-92 250hfe 150mhz to-92*c
awr-194 q8 2sa904 fb ampl - 90v 0.05a 0.2w 512-KSA992FBU (ln)to-92 250hfe 150mhz to-92*c
awr-194 q9 2sc945 lv err amp + 50v 0.1a 0.25w 512-KSC2383YBU to-92L 600hfe 250mhz to-92
awr-194 q10 2sa733 lv err amp - 50v 0.15a 0.25w 512-KSA1013YBU to-92L 40-700hfe 180mhz to-92
awr-194 q11 2sd712 lv pass + 100 4a 30w 863-MJE15032G pnp to-220 55to300hfe 8mhz to-220
awr-194 q12 2sb682 lv pass - 100 4a 30w 863-MJE15033G pnp to-220 55to300hfe 8mhz to-220
awr-194 d1 sib01-02 power 200 1a 512-1n4004
awr-194 d2 sib01-02 power 200 1a 512-1n4004
awr-194 d3 sib01-02 power 200 1a 512-1n4004
awr-194 d4 sib01-02 power 200 1a 512-1n4004
awr-194 d5 xz-060 main zener 6v zener 0.5w 512-1n5233b
awr-194 d6 1s2473 fast 100v 0.1a 512-1n4148
awr-194 d7 1s2473 fast 100v 0.1a 512-1n4148
awr-194 d8 10E2 power 400v 1a 512-1n4004
awr-194 d9 10E2 power 400v 1a 512-1n4004
awr-194 d10 mz-177 shunt reg 17v zener 0.5w 512-1N5247B
What model is it? HG?
Power Supply
its a euro model im in uk is there any chance you can make this into a docket where i can email it to mouser instead of typing this all out
Heatsinks
Hi Elektronror,
Sorry to hijack thread a second but it maybe useful for the OP, where did you get the heatsinks from when you added the 2nd pair of transistors
Got a part number?
Cheers
Steve
Take a picture of your power supply. The HG models has double Q11 and Q12.
You have to do some of the work. :thmbsp:
Cut and paste this list into the parts list importer (free registration required)
647-TVX2A221MCD
647-TVX2A221MCD
647-UPW1A470MDD6
647-UPW2A470MPD1TD
647-UPW2A470MPD1TD
647-UPW2A470MPD1TD
647-UPW2A470MPD1TD
647-UPW1H2R2MDD
647-UPW1H2R2MDD
647-UPW1V101MPD1TD
647-UPW1V101MPD1TD
512-KSC2690AYS
512-KSC2690AYS
512-KSA1013YBU
512-KSA1013YBU
512-KSC1845FTA
512-KSA992FBU
512-KSC2383YTA
512-KSA1013YBU
863-MJE15032G
863-MJE15033G
512-1n4004
512-1n4004
512-1n4004
512-1n4004
512-1n5233b
512-1n4148
512-1n4148
512-1n4004
512-1n4004
512-1N5247B
currently $16.05
Thanks Mark I Have Placed Order With Mouser Its Just Gonna Be Finding Where Everything Goes On The Board
You're SUPPOSED to check the list against the board visually (eyeballs) before "pulling the trigger" to avoid "wrong part itis" and subsequent "wallet deflateus"....
Which implies knowing how to navigate the board using the "maps" found in the service manual...
the good thing is here i have another sa 9800 which i can copy off of the problem with this was there was a bad hum coming from it
and also the replacements from mouser the part numbers will not be the same as the originals so say for instance what will KSA1013YBU replace on the original board and so forth thanks again mark for the help and insight
The directions are implicit in the data.
awr-194 board name
q3 (q4, q10) locations of specific transistors
2sa733 (2sa904, 2sa733) original transistor type and specifications (to help when looking up replacement)
512-KSA1013YBU replacement
this is not all my data or is an old format if it is exactly from me, because the ksa1013 lead (ecb) arrangement is not specified
you need to download the data sheets (mouser has links on each product's page) because the replacements are NOT the same as the originals
thus there are 5 wrong ways to install it and only one right way. I have posted extensively upon the subject.
search for "replacement transistor installation" in my posts,
http://www.audiokarma.org/forums/sh...placement+transistor+installation#post7939628
thanks again mark for the brilliant help i also wanted to ask on one of the 9800 i have one side of the display is slightly dim would you say this is a display problem or maybe the board driving the display i have a feeling it maybe a suspect display on its way out because if it was a board problem wouldnt the whole display be dim? when i try the dim button left side of display goes bright and dim and right side of it goes dimmer n slightly brighter when pressed
One side of display slightly dimmer
Hi,
I have the same issue where the left channel display is very slightly dimmer than the right. Originally the display was just extremely dim but I have replaced all the components bar the relay on the protect board and all the caps on the indicator board and now, although the display is a lot brighter, the dim / bright button doesn't alter anything as far as the display goes. Mark asked me to check some voltages which are in my thread and am just waiting for him to come back to me when he has the time.
I will follow your thread and if I find out anything I will let you know.
Kind Regards
Steve
ok i have started the rebuild on the power supply board now its a case of locating where transistors what i go from mouser go i knew i should of pulled them out one at a time. its funny because i have two sa 9800 and both power boards look different one has four fuses the other has two so maybe some parts maybe different
