hang on...
your picture = layout diagram that I copied from service manual and posted.
Yes.
careful, you have to use the symbols in the "upside down" diagram and the data sheet to figure out which way the new transistors point.
It doesn't help that they are all "in-line" transistor mounts.
These transistors are all ecb:
awr-194 q1 2sc1735 pwr pass + 100v .5a .8w 512-KSC2690AYS to-126 30 to 300 hfe 130mhz to-92
awr-194 q2 2sc1735 pwr pass - 100v .5a .8w 512-KSC2690AYS to-126 30 to 300 hfe 130mhz to-92
awr-194 q3 2sa733 pwr darl + 50v 0.15a 0.25w 512-KSA1013YBU to-92L 40-700hfe 180mhz to-92
awr-194 q4 2sa904 pwr darl - 90v 0.05a 0.2w 512-KSA1013YBU to-92L 250hfe 150mhz to-92*c
awr-194 q7 2sc1914 fb ampl + 90v 0.05a 0.2w 512-KSC1845FTA (ln)to-92 250hfe 150mhz to-92*c
awr-194 q8 2sa904 fb ampl - 90v 0.05a 0.2w 512-KSA992FBU (ln)to-92 250hfe 150mhz to-92*c
awr-194 q9 2sc945 lv err amp + 50v 0.1a 0.25w 512-KSC2383YBU to-92L 600hfe 250mhz to-92
awr-194 q10 2sa733 lv err amp - 50v 0.15a 0.25w 512-KSA1013YBU to-92L 40-700hfe 180mhz to-92
data from sheets:
512-KSA992FBU (ln)to-92 ecb 120v .05a .5w 100mhz 300-600hfe ----- Q8
512-KSC1845FTA (ln)to-92 ecb 120v .05a .5w 100mhz 300-600hfe ----- Q7
512-KSA1013YBU to-92L ecb 160v 1a .9w 50mhz 160-320hfe ----- Q3 Q4 Q10
512-KSC2383YTA to-92L ecb 160v 1a .9w 50mhz 160-320hfe ----- Q9
512-KSA1220AYS to-126 ecb 120/a160 1.2a 1.2w/20w 175mhz 35-320hfe ----- NONE
512-KSC2690AYS to-126 ecb 120/a160 1.2a 1.2w/20w 175mhz 35-320hfe ----- Q1 Q2
these transistors are difficult to reverse:
awr-194 q11 2sd712 lv pass + 100 4a 30w 863-MJE15032G pnp to-220 55to300hfe 8mhz to-220
awr-194 q12 2sb682 lv pass - 100 4a 30w 863-MJE15033G pnp to-220 55to300hfe 8mhz to-220
data from sheets:
863-MJE15033G pnp to-220 bce 250v 8a 50w 30mhz 70hfe --- Q12
863-MJE15032G npn to-220 bce 250v 8a 50w 30mhz 70hfe ---- Q11
OMG
:tears:
and looking at the picture, it was TOO LATE:
awr-194 q5 2sk34 leave alone, unobtanium
awr-194 q6 2sk34 leave alone, unobtanium
You pulled them OUT of the sockets.
ONE PART AT A TIME GETS PULLED AND IMMEDIATELY REPLACED. NOT ALL OF THEM ALL AT ONCE!!!!!!!!!!!!
Leave alone means leave alone. sigh...
This post is NOT finished until this line has been removed!!!!!!!!!!!!!!!!!!!!!!!!!!!
