Brett Becker
First post ever on AudioKarma so be easy on me.
There is one issue I can't figure out on a beautiful SX-1080 I'm working on. There is no speaker muting delay when you first turn on the unit leading to a nice pop and some impressive speaker cone movement. You can hear the two relays clicking almost simultaneously right after you flip the power switch. One of them being the speaker output relay.
When flipping the power switch, Pin 3 of the PA3004 IC, which is the output of the base to the NPN speaker relay driver transistor, almost instantly goes go 0.8V and stay there which is enough to kick on the relay. I can watch the timing capacitor (Qt) hooked up to Pin 8 slowly charge up to 8V after about 3-4 seconds, which from my understanding is supposed to control when Pin 3 goes high to flip the relay. It's almost like the PA3004 is ignoring Pin 8 for and there is something wrong with the IC. Anyone have any thoughts or experience on this? Everything else looks good on the IC as far as the pin voltages.
Thanks,
Brett Becker
Thanks,
Brett Becker
Might. See if you can dig up data sheet.
