xXColdShotXx
what i worry about is the popping and cracking in left channel and it has better offset than the channel that doesn't pop or crack, which is right channel
i just tested stabilizer board and got +65.2v from 17(pos) and 12(ground),
got -91.2v from 12(ground) and 16(neg)
i got the pin# from sm page 30 of 94. I didn't adjust anything, just tested the mv's and v's
but when i test pin 15(pos on awh-048.) with pin 12(ground awh-048.) i get 152v. there could be something wrong with pin 12(ground awh-048)
go to the stabilizer assembly awr-106, and read one at a time with the red lead, the test pins #16 & #17 I overlooked before.
Then go to the connector on the opposite side of the board and read ALL these voltages:1, 2, 3 (skip 4 and 5) 6,7,8,9,10,11,12,13,14,15 one at a time with the red probe - while keeping the black probe connected to the bare metal chassis ground.
pin 4 - 66.5v should be no reading AC power input
pin 5 - -91v should be no reading AC power input
