pin 1 - -75.8v -62v raw dc speaker power out
pin 2 - 76v +62v raw dc speaker power out
pin 3 - 0V 0v ground
pin 4 - should be no reading AC power input
pin 5 - should be no reading AC power input
pin 6 - 92.1v +85v raw dc in
pin 7 - 25.2v +23v raw dc in
pin 8 - 6v +5.4vregulated dc out
pin 9 - 13v +13.5v regulated dc out
pin 10 - 25.1v +25v regulated dc out
pin 11 - 66.8v +65v regulated dc out
pin 12 - 0v ground
pin 13 - -91.8v -65v regulated dc out
pin 14 - 1.1v -25v regulated dc out
pin 15 - -92.2v -87.5v raw dc in
pin 16 - -92.2v -65v regulated dc out test pin
pin 17 - 66.5v +65v regulated dc out
we are on the same page
The -65v regulator is shorted out, and the -92v it is putting out is making the transistors break down with too high of a voltage - causing the noise.
Since the board can be removed, it is easy to work on. You will soon get a list of capacitors, transistors, goop, mica insulators etc to rebuild the board.
until the power supply is behaving itself, all other readings etc are junk (sorry), so we can not draw inferences from them further.
It would be advisable to keep the unit off until the power supply is fixed. There could be continuing problems with the amps because of the high voltage (25v extra can be bad..) that has been applied. But that is fixable too.
note: the 4 boards (power supply, protection, and two amplifier cards) can be rebuilt externally by someone familiar with them (like me or others) if you care to. I have done it before with good results.heck, I even have spare 1250 boards here...
pin 12 - 0v ground
