Pioneer SX-1280 won't mute
cchean
My Pioneer SX-1280 mute switch doesn't do anything. Besides the obvious possibility of a bad switch, are there any other likely causes to this?
Disassemble it and clean the contacts.
If you're talking about the audio mute there's not really too much to check.
The mute switch generally doesn't get much use, so as one suggested earlier
the contacts might just need cleaned. Other possibilities are what Watthour talked about earlier
concerning the resistors, and cold solder joints at the switch or at the resistors.
I would be surprised if the resistors themselves are bad, but never say never.
Thanks Glen65, I will check those.
