JB8
Well-Known Member
Thanks for the speedy reply, @Watthour !
If I measure across the resistor based on the configuration in the picture below I'm getting roughly 2 mV on both of them. I've replaced most all of the caps and transistors on both the PS and "Audio Unit" so I figured it would be off some. I don't have any experience adjusting the bias on this unit, assuming VR 4 and VR 5 will get me up to the proper range? Also, should I be in AUX function with volume at zero, and does the unit need to be warmed up when the adjustment is made?
