K-Schick
Hey Everyone! I've been reading a lot on here and really appreciating the plethora of great info. This is my first thread.
I just took possession of my first vintage receiver, a Pioneer SX-750. I plan to use it for a headphone amplifier, as well as for speakers. Most likely a daily driver for my headphones at work. I would like to get this running nice and clean, and I may even try my hand at making and finishing a new wooden cabinet, or doing a wood veneer on it.
The receiver is surprisingly clean, but I can tell its been messed with and serviced prior. (There is a sticker in there from a service shop with a 1982 date on it). There are some pins with sloppily soldered on wires, a few pins with no wires (is this normal?), and the C17 & C18 Caps on the Power Supply AWR-099 were swapped out. Other than that, I cant find any other swapped out parts or replacements that are obvious to me. It sounds pretty good to my ear, and the tuner works great, but it has some intermittent popping and crackling going on. It comes and goes, sometimes sounding great for 20-30 mins before it shows up. Sometimes it happens immediately. Of course, when I try to take measurements with a DMM, the damn thing runs smooth as silk and wont pop or crackle.
The popping and crackling is always in the Right Channel, and is the same for all sources. It does not respond to Volume, or tone control changes. Since the popping/crackling is always in the Right channel, I believe the problem is not in the Power Supply section, and is most likely in the Power Amp section.
The Phono source has a constant lower level static and crackle, that is completely different from the intermittent pops and crackles on the other Source Inputs. I'm assuming the Phono Amp Section needs attention. TBH, that is not my top priority, as I'm not going to be primarily listening to LPs, but I would really like to try to tackle that (maybe later?) to get the receiver back to 100%, having zero issues, unless you all think I can easily fix it along with a full re-cap while Im in there.
I did a thorough deoxit treatment (per the super-informative thread by Arkay. Thanks a million for that, btw). I did every switch and knob twice, then I lubricated with faderlube. I also cleaned all the fuse connections (even thought there wasnt much to clean off). I cleaned the molex connector pins for the four Q1-Q4 transistors on the Power Amp as well.
I have also gone through the steps that MarkTheFixer listed in this thread:
http://audiokarma.org/forums/index.php?threads/pioneer-sx-750-right-channel-crack-popping.572125/
I exercised the VR2 trimpot in the Power Amp (that did not stop the popping), and later when I shorted the 26 & 27 pins, I did not hear any pops, but then again the damn thing quit popping after that, and I didnt hear another one for hours. (of course).
I have taken Voltage measurements on EVERY Pin on Power Amp AWH-046, Power Supply AWR-099, and the Power Supply Assy AWR-100. Nothing seemed more than 5-10% out of the recommended spec. If you guys thing its pertinent to list all of them Id be glad to, if that makes it easier to help me.
My DC Offset is L: 27mV, and R: 27 mV.
Voltage readings were all taken with the STV4H Diodes disconnected from the heat sinks, because I started to partially take this whole thing apart. (I hope this won't effect readings to a large degree). I can reconnect them to get more voltage readings if you guys think that's better/more accurate/safer for the receiver.
The popping and crackling did not change after any of this.
I'm gearing up to do a full recap of the Power Amp AWH-046, and the Power Supply AWR-099. I know that replacing some Transistors is a good idea too, but Im not sure of how many, or which ones are the most important for me to replace. Before I place a ReCap order, I just want to make sure that Im not missing anything else, or leaving anything out, like another board I should recap, a certain set of transistors, etc.
I've never recapped a receiver before, but hopefully Im on the right track, and some info from you guys will help set me off in the right direction!!
Any help, guidance, or suggestions are greatly appreciated! Thanks for your time!!
