Pioneer SX-850 Relay Replacement
tsd71
RIP Tom Petty
what is the correct replacement relay with mounting flange for the sx-850, and where can i get one would it be Digikey part # Z191-ND (LY2F-DC12_24)?
Thanks
I suspect you have read this thread : http://www.audiokarma.org/forums/showthread.php?t=150439
The only difference I can see is that on the 737 et. al. the flange is on the top side of the chassis, while on the 850 the flange is on the underside if the chassis..
I think EchoWars's fix is still applicable.
The only difference is in the Pioneer part numbers according to
http://parts.pioneerelectronics.com
with the 737, 838, 939, 1010 use the asr-007 a 24v 4pdt relay with the flange on the bottom
and the 850 & 950 use the asr-019 relay which is also a 24v 4pdt relay with the flange on the bottom.
