automaat
Hi everyone, I am a tech working in Canada. My focus is organs, synths, tape gear, etc...
My weakness is Power Amps. I took this one on thinking it had a good output section and trouble in the front end. Turns out the left channel was blown. Fuse open. One output device shorted.
I changed the output transistors as well as all the other transistors in the channel. It still acts like a short when I power up through a bulb-limiter.
What might be the next thing to check? The good channel measures the same resistance to chassis from fuse holder as the bad. The bad channel previously had a low impedance path to ground.
thanks for any help,
first post, long time lurker,
Carl
p.s.
I will soon be buying D. Self's power amp book (only own the small signal one at the moment).
Carl
p.s.
