jleon92f
Addicted Member
Recable it. The stock cables sound terrible.
OK thanks. Will do, any suggestion about what to replace them with?
Thanks,
John.
Hmm, mine had black cable, are we sure someone hasn't already recabled it? Yours looks grey.
I've been thinking about that vinyl Parts Express sells for recovering speakers. It's wide enough that it'll cover the entire base on a PL-530/550/570 in a single piece. The method I would use would be to remove the top layer of vinyl and leave the bottom toffee colored layer as a substrate for the new vinyl, even leaving the surface tackiness from the old top layer since it actually helps the new material to adhere.
John
I started to take it apart...
I am looking into the new vinyl covering.
Thanks,
John.![]()
Nice job! looks great! I have a lighter color PE vinyl, shown in picture.
Thanks,
John.![]()
I cam make decals too.
Thanks,
John.![]()
Is that the oak? That should look great!
John
I commented earlier that your cables were different from mine, but it looks like the platter mat is different too, so maybe it's a different year/version altogether?
That might be a mat I just put on it? I have some many items here hard to find anything. I put new RCA ends on the cables that came with it.
Thanks,
John.![]()
Change the whole cable. The stock one is a crappy steel center conductor and sounds like complete crap! All I used was some component video cables and cut off one end and soldered them in. The difference was like AM vs FM radio.
Well, look at it this way, you're doing many people a service. I had one of these 'tables (and wish i still did) and would have loved to veneer it, but was intimidated by what would have been involved.What a PITA this has turned out to be...The way they mounted the motor bezel is stupid! You have to take everything out to get to the last screw!
Oh well, I am into it now, no turning back!
Thanks,
John.![]()
I might have done it if this thread were around a few years ago.
And if I may offer an unsolicited suggestion, consider reinforcing or damping (or both) the plinth box as you put it back together. The 550 seems like a good candidate for that; it's made out of pretty thin chipboard.
