Damn, that's too bad. Sorry to hear that, John.
I had a tough time with the PL514 I recovered and actually had to re-do it once. Where I had trouble was at the edges. The material is so thick that it doesn't want to make a sharp 90 degree transition from the horizontal to the vertical. I ended up with lots of bubbles along the edges.
I had to lay the material on the top surface (correctly the first time! no repositioning possible) and, making sure that it didn't start to stick to front, back or sides, smooth it out right to the edges. I then had to forcefully run my finger back and forth along the edges, one edge at a time, to crease the vinyl (still making sure that the vinyl didn't start to grab the other surfaces). I could then wrap it around and smooth it onto the vertical surfaces.
I still had a few bubbles but I was able, with difficulty, to get rid of them by CAREFULLY making tiny cuts with an Xacto knife, corresponding to the little fake grain grooves in the vinyl. I could then force the air out of the bubbles. Some required the EXTREMELY CAREFUL use of a heat gun on the lowest setting to shrink the vinyl over the bubble. Too much heat will cause the adhesive to boil, making it a little lumpy when it cools. This shows on the surface.
All in all, I'm pleased with the results but I'm in no hurry to do it again. On balance, I think it would actually have been easier to do it in real walnut veneer.
John
