I agree, it was crazy the first time I realized I could hear them inhale. The level of talent that some of them had back then is amazing when you consider what we are hearing is how they sounded not how they sounded after a computer processed it.
I ended up using the K40-9y for the coupling caps. I started out with the Auricaps but the K40s ended their month and a half journey from Russia just as I was finishing up. I did run it for a bit with the Auricaps but unfortunately, I switched speakers at the same time I switched the caps. The ones I was using for testing got moved to work and in-wall speakers that were just sitting on the workbench took their place so it was impossible to tell any sound difference. I may someday switch back for comparison but the amp is not only really heavy but top and back heavy and awkward to move so it will likely be awhile before I try anything. But I did end up with enough spare parts that I keep thinking 'maybe I should build something else'.
It is funny that you ask about the 5U4GBEH; I kept thinking that I should research the sound it makes at startup. I guess that is just what they do.
I went with the 6L6GC because I had a few spares of those. It was my 'hey, this could be cheap because I've already got the tubes'. The amp that got me started in all of this is a Heathkit A9C with 6L6GB tubes. I picked up a few 6L6GCs to try in it so that was my starter parts. But of course the 58 year old GE tubes already in it sounded the best of any I got. Which lead to the irony of it that I didn't end up using the spare tubes I had I picked up a pair of GE 6L6GC tubes from '63 mid project.
For the last decade I used a Sony amp, granted it was just a Sony but it was their high end ES line. When I bought it I was excited because it was digital and 7.1 and the sound was going to be amazing. However, no matter what adjustments I did it just never had a sound that made me
want to listen to it. Listening fatigue would set in really fast so I'd rarely use it. I actually often missed my simple, and cheap by comparison, 2 channel Kenwood that it replaced. I was starting to think I just didn't like music that much anymore. One day I was up in the attic and remembered the old tube amp my Dad had built nearly 60 years ago so I got it down, dusted it off, and since I hadn't read anything on here to know better, plugged it in. I hooked up two tiny old speakers that I just hadn't gotten around to throwing away and was shocked at how good it sounded; especially considering it was just mono going to two speakers. I kept it in the garage for music and started replacing capacitors on it. Then I found myself finding projects and excuses to be in the garage and listen to it. My fancy receiver was getting beaten by a mono amp that, even adjusting for inflation, cost 1/4 as much. That was when I decided it was time to build one for the living room.
I have a couple pictures of the under side of it, I'll have to get them off the old tablet I used. To be honest it is a bit embarrassing compared to the perfectly laid out wiring I see on here but I don't have any hum
