jdsalinger
Thanks for the heads up.
It is funny that you ask about the 5U4GBEH; I kept thinking that I should research the sound it makes at startup. I guess that is just what they do.
It is not much harder to drill steel you just need to start a pilot hole with a small bit. I like a steel chassis a little more because steel is stronger per similar thickness. Also steel takes paint better than Abluminum.I'm trying to decide between an aluminum chassis and a steel one (both Hammond ones). The aluminum would be easier to work with but I like that the steel one comes in black so I don't need to try to paint it. Just curious if I'd likely really regret going for the steel when it comes to drilling.
Also, thank you for the picture of your setup. I was planning my layout in a somewhat stupid setup for appearance with the power transformer in the middle but after looking at your layout it hit me that it is much wiser to keep the power to one side and the signal to the other as much as possible.
You should talk to a person at Edcor as the shopping cart probably added up the shipping costs per each transformer. I just ordered some OPTs a few months back and I could not be happier with their performance or appearance. It took them 3 weeks to ship them to my door. I ask them about the shipping and apparently, they had complaints about "combined" shipping so on USPS they ship the transformers 1 to a box. That sucks but still their price is very competitive.So.... Just put the 2 OT's , 1 PT and Choke into the shopping cart at Edcor. Shipping charges range from $57 (UPS and FedEx) to $103 (USPS Priority Mail)!!!!! Yikes!
Is this typical with Edcor??
I am going to switch my rectifier to a Sovtek 5AR4 that I have. It is smaller, dead quiet and very gradually brings up the voltage. The 5U4GB jingles and hisses constantly & it spikes to 575 V or so immediately, then drops down when the tubes warm up (?)
The only issue is that the 5AR4 will give about 30 more volts or so. You'd have to drop some voltage.
How do the Mundorf compare to the Auricaps and Russian PIOs?
Care to share a pic of the innards?![]()
I just ordered some 0.33uF Jantzen Superior Z caps
These will replace my 0.22 KimberKaps. I have the Superior Z caps in my preamp.
Nice, what will going to .33 change for the sound?
I got 442V B+ with my XPWR-222 Edcor power transformer (375-0-375). I added a 100ohm 10W power resistor right after the 10H choke and now I'm getting 406V B+ with the 5U4GB.
You could also probably put it between the 10uF and 100uF filter caps too.
Thanks very much for that explanation. I'm considering the EDCOR XPWR155. It's rated at 200mA and should to the job nicely.Intentional. There were other KT88 projects like this one http://diyaudioprojects.com/Tubes/KT88/ that call for a 750V CT power transformer. I figured it was safe. You'll be OK with 700V CT too.
There are several other builders who actually use a much higher B+ than 400V ( 440 or 450 maybe?), so you're safe and probably wouldn't even need to add the power resistor like I did.
I chose the XPWR-222 for it's 350mA rating (way overkill, but not much more expensive). The Edcor that others were using seemed a bit low to me (175 mA I think?). The Hammond is 201mA and will be fine if that is what you use. Secondly I chose the 222 because it didn't have the un-necessary 240VAC primary. Simple as that.
