Plate Amp Connections
A plate amp normally connects internally to the subwoofer. You can then either hook up your speaker outputs from your amplifier to the high level inputs (middle connector) -- say from the 'B' speaker outs on your main amp -- or via 'Y connectors from your amplifier pre-out/main-in to the line-in (top connector) on the plate amp.
