Brilliant idea! I have 5,000 LPs — all I have to do is buy 5,000 of those platters! Consider it done.That's some platter, I wonder what a record would sound like if it was glued to it?
I do both. Kinda. I have a SAEC SS-300 metal mat. Some unknown alloy with a different resonant frequency that kills all resonance in your platter totally dead — so they say. So I do put my records on a metal surface. Is that the same? Sounds great by the way.Should I use a mat or just lay the record on the metal surface?
I find the concept of vinyl directly on metal a little worrying. I am no big mat fan either, but I'd try some thin felt or cork between the two substances just for protection. Do experiment though, by all means.
I admit it didn't even occur to me that there might be folks out there who place vinyl directly on a metal platter. I'm not going to judge that approach because I lack personal experience with it, but I think I am going to revise my working hypothesis about the origin of what I have hitherto regarded as "paper scuffs" on second-hand records... (until convinced otherwise).
Perhaps a thin cork or composite mat to prevent the metal platter from scratching the LP or vice-versa.
Lot of misinformation showing up in this thread. The OP has a VPI Prime with the aluminum/SS platter. This platter is so finely machined and polished that there is NO danger of scratching a record, certainly no more risk than any other 'table.
Good point! So I'll need 10,000 platters. No problem....of course, sides 1 and 2 will have to be on separate discs....
actually you would need 10,000 if wanted to listen to both sidesBrilliant idea! I have 5,000 LPs — all I have to do is buy 5,000 of those platters! Consider it done.
