Premium KT88s worth it
I run Ruby KT88s in my Latino ST120, after I talked with Craig at NOS Valves about tubes, he convinced me to spend the extra cash on the tubes for the pre-amp section of my amp, NOS Mullards and NOS Telefunken.
As Craig explained it to me, you will realize more of a sonic difference with the better tubes in the pre-section. He said the KT88s push out the power and don't do a lot sonicly.
I took his word for it and can honestly say I'm very pleased.
Just my $.02
BTW, what is the difference between the KT88 and 6550 and why would I chose one over the other?
mike
Similar power ratings, but somewhat different methods of getting there. The 6550 is a beam pentode like the 6L6. The KT-88 is a kinkless tetrode.
http://www.drtube.com/datasheets/6550a-ge1972.pdf
http://www.drtube.com/datasheets/kt88-mov74.pdf
From what I understand the 6550 was designed for industrial applications (hence the four-digit number), the KT88 was designed solely for audio work.
....The KT-88 is a kinkless tetrode.....
OK, couldn't pass it up....are we talking whips and chains stuff, here?:whip:
I've got KT-88s but never walked in on 'em......hope they're well behaved when I'm out.
Care to elaborate on that comment?
Cheers,
David
I would highly recommend the GL's or a pair of EH KT90's. The KT90's are quite a bit cheaper, and may even possibly edge out my GL's. I bought mine through Jim McShane, which were slightly more, but I am comfortable with what I received on both accounts. McShane has no problem answering your questions and/or steering you in the right direction regardless if he stands to make or lose money. He will and does stand behind his products. You can get them cheaper else where, but you can rest assured that with Jim your getting a well tested/matched/backed product. Here's his site: http://pages.prodigy.net/jimmcshane/tubes.htm
You won't be disappointed.
Ron
I wanted to hear the difference between the Gold Lions and the EHs but couldn't; both sounded good to my ear. Your results may vary. Have not heard winged c kt88s.
I tried the EH and then tried the GL. I heard a difference, but not a dramatic one. The EH are a good bang for the buck.
Lou
Cheers,
David
It's just what they are. You're more than welcome to use a Ouija board to contact the Genalex engineer who came up with the terminology 60+ years ago. I think it had something to do with there not being a "kink" in the frequency response curve found on the early prototype tetrodes.
I replaced the EH6550's in my Jolida 801A with Tung Sol 6550 reissues and they are much smoother, and don't have the brightness that the EH's did.
A "kinky" tetrode. :)
From an AA thread
http://www.audioasylum.com/cgi/t.mpl?f=tubes&m=224977
