Very nice work! That armboard was drilled for that arm, unfortunately the arm that I pulled off wasn't in the greatest shape.
Good to see you honing your lathe skills as they are very handy to have. Now that you have an idler wheel to work with, make sure you adjust both the 33 and 45 idler stop screws visible in the shifter gate plate. Run them in till the idler wheel no longer drives the platter and start backing them out till you feel the platter being driven. Don't put to much tension on the wheel, just enough to smartly accelerate the platter and no more.
Did you mention what cart your running yet?
On Edit: There needs to be a clip on the end of the pin that the idler runs on with a fiber or teflon washer. The idler is liable to ride right up the pin if it's not perfectly square to the motor shaft and the inside of the platter.
BillWojo
Up ‘till today I had lubed moving parts on this with “gun oil”, either Hoppe’s or Outers brand; forgot which. Those seem to be around a 10 weight, sort of like sewing machine oil, I suppose. The platter bearing spec from Russco, circa 1982, was “standard 30 weight motor oil” which I know some people don’t like to use, apparently because of additives. While I do have some 30 weight around, I also had an open bottle of this full synthetic 5w/50. If it’s good enough for my 550HP Shelby, it should be good enough for a 33/45 rpm Russco..
BTW, Bill - @BillWojo it takes about 1-1/2 caps full of this to completely fill the bearing to overflow when the platter back in the bearing - both Oilites are in oil bath. It does take some time for the platter to settle. I just used regular Teflon thread tape to seal the grub screw.
Duane:
That 30wt recommendation is probably standard non detergent 30wt oil….Believe I’ve mentioned that these tables can be manipulated a bit by oil selection, for some reason my notes are lacking in relation to the topic.
As long as you check the oil every once in a while, don’t think it would be be a problem to use your synthetic motor oil, but I wouldn’t fill and forget![]()
Since my plinth is this cardboard box.. No, not yet.
Still have to figure out a platter mat - and then the plinth. My wife isn’t happy with the cardboard..
Since you have it operating, I’d use one of Mike’s fine plinths from above and get an idea of baseline performance. That’s the best way to judge improvements….
