Pricey cables
Status
Not open for further replies.
That's interesting - use the mechanical inertia of the motor / generator combo as a low-pass filter. You would totally eliminate EMI coupling across inter-winding capacitance. I like the way you think but there may be two different discussions going on here - one is about the utility / futility of "advanced" power cord design - the other is about setting up an experiment to demonstrate the presence / absence of audible differences. My input / interest is strictly related to the former - which may explain some of the confusion.
OK understood. I was thinking about those who saw fallacy in an expensive 5' power supply cord plugged into household romex which in turn connects to the grid and whatever ugliness is going on out there. With a pure sine wave isolated power supply, one might connect an expensive cord right to it and eliminate all the other assorted problems. I am not talking about some garage system and certainly not my own, but more like some $100k systems where little expense would be spared in achieving the best sound reproduction possible.
Perhaps what loopstick is eluding to is that the inverter stage of a pure sine supply is often a switching power supply. Something considered unholy of sorts, by many audio buffs. Point being, that's not necessarily a sure bet for "pure" AC power.
That said, I am presently working on my own home brew double conversion power supply just to experiment. I don't believe there is anything materially wrong with the AC supplied by my house wiring, but we'll see what happens. I'll be using a Tripplite PR-60 power supply to convert 120Vac from the wall down to 12Vdc, then a Samlex pure sine inverter to convert the 12Vdc back to 120Vac.
PS Audio has gone to Class D amplification for the Power Plant designs. The older units are Class A/B amplification. But either way, I think you are getting "audio quality" power from them. And some folks do feel that UPS power supplies for computers are not adequate for this application. Is it cheap? Nope. But it should be effective.
Regards
Mister Pig
With a pure sine wave isolated power supply, one might connect an expensive cord right to it and eliminate all the other assorted problems..
If the implication of the power cord is that it cleans up dirty AC then there would seem to be little need if one had the proverbial "pure" AC.
Of course, demonstrating clean up of the AC is pretty easy (although not suggesting by means of just a different cord). Of more interest would seem to be what's happening on the DC side of the gear, where the supply should be providing "clean" power to the circuits.
Regards
Mister Pig
The beginnings of my experiment.
Beer bottle for scale, and refreshment after lugging around that Tripp Lite power supply. It must weigh 35-40lbs.
Double conversion using such low voltage is a real bugger though. Even with the 60A power supply, that's only enough current to get about 50% capacity of the 1000W Samlex inverter.
Q 1: Why buy a Ferrari when a Hyundai will get you from point a to point b?
Q 2: Why buy an Omega when a Timex tells great time?
Q 3: Why buy an expensive cable when all it does is connect component a to component b?
A: Because I feel like it. Mind your own business.
Lotta inverters deliver dirtier power than what is available from the grid.
Yeah, maybe. I mentioned that possibility earlier in the thread.
The Samlex spec is <3% THD. The problem is I don't know what it is normally on the lines in the house. :dunno:
I have PC scope that has spectrum analyzer function but I don't know how accurate it really is at calculating THD.
I googled the keywords:
single IEC power cord audiophile
and found a number of audiophile power cords for less than $25 a piece. I tend to be a skeptic of audiophile power cords. Here's one page I found that tries to explain why they work.
http://www.gcaudio.com/resources/howtos/powercords.html
I don't agree with the comparison with speaker cables, as long as you have adequate filtering in the power supply and/or before it (RFI/EMI).
Also see
http://www.head-fi.org/t/219202/its-done-power-cord-shoot-out-22-power-cords-reviewed
I never tried comparing power cables, myself.
If the implication of the power cord is that it cleans up dirty AC then there would seem to be little need if one had the proverbial "pure" AC..
I was thinking that same thing.. An AC synchronous motor driving a generator could be much less than a $3k cord, well maybe..
The pwr supply of properly designed amps is designed to clean the AC before it enters the signal path. Using pricey power cords is akin to washing your car prior to taking it to the car wash.
Then considering how generation equipment creates current over how solar converts energy passively in a cost effective manner kind of makes generation obsolete just like how the electric grid in Europe disappeared because it was outdated....and ineffective !
So tell us what you learned from your experiment...
Let's keep the train on the tracks laid by the OP folks!
Regards,
Jim
OK here's my take on the OP. A test was done with all the variables (except the power cord) being expensive SOTA stuff. The idea was to minimize the effects of everything else so that the effects of the power cord could be better discerned. So he did the test and he could not hear a difference - neither could a host of audio professionals.
This sort of testing has no appeal whatsoever to engineers cuz it's subjective. OTOH it was deliberately subjective in order to appeal to an audiophile audience and it does leave a lot of room for people who do hear differences. So the test really doesn't add anything new to the debate. That's fine. The direction in which this thread seems to be heading relates to possible mitigation effects that a power cord might provide in situations in which the AC supply is non-ideal.
Status
