Pricey cables
Status
Not open for further replies.
Which begs the question, "Did Harry Pearson buy the equipment or benefit from permanent loan?"
He owned a great deal of gear along with enjoying extended evaluation periods for others. Since he had a continual passage of all manner of such, he had the luxury of experiencing a wide range of choices. And I was lucky enough to benefit, too.
At any given time, it wasn't unusual for him to have three different stellar line stages and power amplifiers at the same time to audition. I remember comparing the Atma Spheres along with the Edge References and the VTL Wotans on the Nolas. The Krells to the back left drove the woofer towers. While the Edge Reference amps were absolutely gorgeous with engraved lettering, cool lighting and counter sunk machine screws, my favorite was the comparatively homely looking Wotans in the rear. Which is why I use their little brothers in my system today. :)
BTW, the tape on the floor facilitated using multiple speaker systems having differing optimum positions in the room.
The electrician in me would agree with Mr Pig that a pure sine wave inverter or generator of some sort would have obvious advantage in that it would be a way to control and purify the entire electrical supply
Just a caution about the "purity" of the sine wave. Your "pure" sine wave acquires ugly amounts of harmonic distortion in the rectifier stage. The purity - like a girl in trouble - is a temporary thing.
A friend of mine had, probably still has a pair of Ichibans that he ran to some Duntech Sovereigns. Those were mighty fine amps, a predecessor of the Wotan's as I recall. I would have hated to re-tube that amp, as it had a dozen EL 34 a side.
Regards
Mister Pig
Too much trouble!
If I'm happy with how my System sounds even without all these ex. Room treatment,cables and on and on,than that's okay also.Some of us can or could not afford all the efforts that have been mentioned on AK all these years and some not just for monetary reasons but that does not mean that we can not enjoy what we have for what it is!You folks that like to enhance your systems sound by any means go ahead if your results give you joy but remember outside of some easy to do ex. speaker placement etc many of us have to live/hear what we can do or have and that's plenty for some of us:)
Are talking about the rectifier stage of the component. That would be on the component then, and not applicable to the topic of household electrical supply. What you are trying to hear is if there is a change with the power cord, and this way you know you are supplying the power cord with a pure AC signal. So if something changes with the power cords, then is can be observed that there are differences.
Regards
Mister Pig
Yes! That was the earliest of the "two floor" designs.
Retubing my MB-450s is bad enough with eight 6550Cs each - the Wotans use twenty-four per amp each of which needed to have its bias individually set. Which as a techie kind of guy I ended up doing while visiting Sea Cliff.
Regards
Mister Pig
Perhaps what loopstick is eluding to is that the inverter stage of a pure sine supply is often a switching power supply. Something considered unholy of sorts, by many audio buffs. Point being, that's not necessarily a sure bet for "pure" AC power.
That said, I am presently working on my own home brew double conversion power supply just to experiment. I don't believe there is anything materially wrong with the AC supplied by my house wiring, but we'll see what happens. I'll be using a Tripplite PR-60 power supply to convert 120Vac from the wall down to 12Vdc, then a Samlex pure sine inverter to convert the 12Vdc back to 120Vac.
Then there is an avenue of approach that many don't consider....
Many have spoken about a dedicated direct clean source of power like a dedicated power pole...so what about a direct source from a solar panel system that only has an inverter to deal with ?? Filtering a solar panel system would probably create more noticeable gains than any fancy power cable. Then without the right speaker wire, interconnects and jumpers between the pre and main amp, how can a person notice an improvement with clean power ?
Also, a solar panel system pays for itself....and how much do these fancy power cables cost ?
Monkey see, Monkey do....for the price of some of these power cables Sun City can install a solar panel system that would provide clean AC and better sound over all !
I know that he had 3 mega systems. Someone somewhere posted photos of them when he passed away.
There were three rooms he simply named 1, 2 and 3.
Room 1 in the front of the house contained the "Super Maggies" for his HT / multi-channel system. It wasn't "pretty" as he had covered all the windows with black drapes to eliminate light. It's also where I stayed during visits. He tended to crash early, so I could enjoy that system late into the evening. Many people are unaware he was also a big film buff and had a huge video library. Used EMM Labs transport/DAC, Krell processor into C-J MET-5 preamp, Edge multichannel amp, Magnepan 20.1 mains, dual CCR centers, 1.6 rears and five Nola thunderbolt subs. And a Runco projector with 100" screen.
Room 2 was the smallest one located between the other two. Its inhabitants changed more frequently. I heard a wider range of stuff there over the years. The last time I was there, it housed a VPI turntable with power supply, EMM Labs SACD player, Veloce line stage and McIntosh 2300 amps driving Maggie 3.7s. I met Micheal Hobson - formerly of Classic Records and now with HRT that time. He brought some wonderful one off pressings for Harry. Who most often had several copies of his favorites.
Room 3 is the one where the "big" reference system lived. That's the only one that could fit the Clearaudio Statement. :)
There was at least one photo on AK that was a photoshopped fiction.
Are you talking about the rectifier stage of the component? That would be on the component then, and not applicable to the topic of household electrical supply.
The point is that the pure sine loses its purity - by design - upstream of filtering and regulation no matter what cable you use.
Filtering a solar panel system would probably create more noticeable gains than any fancny power cable. Then without the right speaker wire, interconnects and jumpers between the pre and main amp, how can a person notice an improvement with clean power ?
Well, that's where the canard lies. The biggest problem is not the AC coming miles away from your local sub station. It is the myriad of noisy villains that live in modern homes constantly spewing noise back into the AC - including nearby audio components.
Yes, one needs a clean AC source, but that's half the battle.
Some of us can or could not afford all the efforts that have been mentioned on AK...
Here's some advice for the most bang-for-modest-buck: Buy a Tripp Lite ISOBAR surge protector/conditioner for your source components - tape, turntable and CDP.
It will not only protect them, but provide a level of filtering that you will most likely hear as a slightly darker background. With more detail evident.
Tripp Lite ISOBAR 2 at Amazon
I have already done this and I am most happy now with what I have and hear!Thanks:)
Been using a Tripp Lite ISOBAR 8 for 8 or so yrs. It lets you know when to replace it. Lifetime Warranty and $10,000 Ultimate Lifetime Insurance for connected devices. I can hear the anti MOV audiophiles in my sleep. Yada, yada...........................
The electrician in me would agree with Mr Pig that a pure sine wave inverter or generator of some sort would have obvious advantage in that it would be a way to control and purify the entire electrical supply,
This was why I mentioned a generator. A resourceful person could connect an ac motor with a ac 110v generator and effectively isolate anything coming from the grid, service drop and even branch circuit romex.
That's interesting - use the mechanical inertia of the motor / generator combo as a low-pass filter. You would totally eliminate EMI coupling across inter-winding capacitance. I like the way you think but there may be two different discussions going on here - one is about the utility / futility of "advanced" power cord design - the other is about setting up an experiment to demonstrate the presence / absence of audible differences. My input / interest is strictly related to the former - which may explain some of the confusion.
Status
