WOW! This is contrary to an awful lot of the conversations here and elsewhere, but I appreciate your perspective. My EVO 300i is coming with stock EL34s and I was wondering, and frankly a little skeptical, If I would hear the difference KT150s would make (as others have suggested I consider doing).Often, they don't.
There's nothing different about anything, many power tubes use the same pin out, if the builder selects the cathode resistor or sets the bias such that the amp will work and bias up with any power tube in it from that series.
Better amplifiers will give you a means of adjusting bias so that each tube can work its best in circuit.
Better still is an amplifier that was designed to make low distortion, hi fidelity sound with a specific tube type.
Often the transformer is chosen and the circuit optimized for a specific type of output tube, you should use that tube type rather than sub in something that's going to disturb the apple cart with regards to the original builders intentions.
My advice.
Tube rolling is a slippery slope to a mental disease. If you can afford it, great, many people who can't afford it get sucked in by the flowery language but have no way to objectively tell if the tubes they just carelessly stuffed in are even working. Often they're not. They are often mismatched old, worn out, tubes. For these people the magic is in the distortion and artifacts left by running grossly mismatched and downright dead tubes. These folks amplifiers often can't make even 1 watt before distortion. They'll throw a fit if you try and tell them they need new tubes. They spent thousands rolling to find the perfect set, but the perfect set doesn't work, produces terrible distortion and rounds off the frequency extremes. My long winded advice. Don't get involved. Before you spend any money on rolling tubes, you should spend a few bucks on the equipment with which to test your equipment. If you're not taking measurements, you're not making improvements. Once you own this equipment, I think you'll find that the whole topic is a bunch of hot air.
PrimaLuna advertises that the EVO 300 and 400 units are compatible with KT88, KT120, KT150s in addition to the stock EL34s but they do not claim that the amplifiers somehow morph to take full advantage of the bigger tubes. That was the genesis of my original question. I sure do not want to spend the $$$ for new tubes, which may operate, but not to their full potential.I'd be concerned that the power transformer designed for EL34s is not likely to have the extra capacity on the heater supply to feed those tubes on a long term basis. (they draw more current)
The bias surely will not be optimal.
If you're not prepared to modify the amp to alleviate these problems then you're probably best served by the tubes that it ships with. If your goal is High Fidelity, leave it alone.
If you want to create a personalized distortion generator, then nothing I or anyone else can say will deter you.
Do these people who claim these massive improvements give you any data? The evidence is easy to produce and interpret if in fact there is am improvement. My guess is that most of them don't own any measurement equipment with which to quantify the changes. They're relying on their ears and what the internet told them they're supposed to hear. When you begin to investigate these bizare claims on your test bench they collapse like a house of cards.
My rebuttal is this, tube rolling is fun. If having fun is “hot air” then I guess I live in the desert lol. Admittedly tube rolling puts you squarely into the audio gear as a hobby part of the audiophile world. I tend to switch between being a gear head and getting lost in the music. Once again, your hobby should be fun. If I were looking for better measurements I’d use solid state amps. The beauty of tube rolling is that I can have a system that sounds different by simply swapping tubes. Why have one system when I can have many? Plus you can often times save money by using alternative tubes. Many mainstream tubes have become crazy expensive.Often, they don't.
My advice.
Typically amps that can use KT88 can also use the newer variants of kt90, kt120, kt150, etc. but they won’t generate any more power because you’re still using the same power supply. The same thing goes for using a 6l6gc or 7581a instead of a 5881. Just make sure you don’t go the opposite way! Don’t put in kt88 if the amp was made for kt120!PrimaLuna advertises that the EVO 300 and 400 units are compatible with KT88, KT120, KT150s in addition to the stock EL34s but they do not claim that the amplifiers somehow morph to take full advantage of the bigger tubes. That was the genesis of my original question. I sure do not want to spend the $$$ for new tubes, which may operate, but not to their full potential.
Your question about others showing their data was rhetorical, correct? I have not seen any data to support their suggestions. To be fair to them, I always understood their suggestions to be subjective and not objective.
I briefly mentioned a possible technical reason why different output tubes can improve performance in a previous post. To expand on that and address the “Where is your data?” question I’ll simply ask what data confirms to what things sound like? We don’t listen to resistors. Speakers have their own distortions that add and cancel distortions as well as present a varying load to the output tubes. And all of that varies not only with frequency but what combinations of frequencies the speaker is trying to produce as well as the amplitudes of those different frequencies. The interaction of electrical signals being turned into physical ones is insanely complicated. I’m not aware of any measurements that can capture or quantify what is happening. Ultimately we are not listening to the amplifier, we are listening to the amplifier driving the speakers.PrimaLuna advertises that the EVO 300 and 400 units are compatible with KT88, KT120, KT150s in addition to the stock EL34s but they do not claim that the amplifiers somehow morph to take full advantage of the bigger tubes. That was the genesis of my original question. I sure do not want to spend the $$$ for new tubes, which may operate, but not to their full potential.
Yeah, there will ultimately be tubes you prefer over others and so the rejects end up sitting around. Of course you could sell the ones you aren’t using, lots of people could use those kt120s.I am very familiar with the desire to spend money on different tubes. Bought a Primaluna Dialogue Two integrated probably 15 years ago. Same year bought some Tung-Sol KT120s, just had to have them. Tried them, they been sitting in a box for at least 14 years. Have been running NOS RFT EL34s in it ever since.
To be 100% clear, sound quality can easily be measured and quantified. For under $1000 a person can set themselves up to measure the performance of tube amplifiers then when a change is made you can compare what you measured before the change to what you measured afterwards to see if an improvement was made.Your question about others showing their data was rhetorical, correct? I have not seen any data to support their suggestions. To be fair to them, I always understood their suggestions to be subjective and not objective.
There, I fixed it for you.You'll never know unless you measure.
I know exactly what you are saying.That's not what I'm saying at all.
What I'm saying is that I've seen enough evidence on my end to suggest that we need to keep our fallable ears and imaginative minds in check by measuring things from time to time so that we can know that we're traveling in the right direction.
I've personally built an amplifier that makes 3/4 of a watt, nearly ten percent distortion, yet still sounded beautiful within its extremely limited range. It used 6sn7 as a power tube, and was built entirely of salvage. Given that I was running it on 100db/w efficient speakers it provided plenty of volume. Fact is it wasn't a very good amplifier, had I trusted strictly my ears, I'd have thought it sounded good enough and perhaps continued using 6sn7s as power tubes.
Reality: It sucked as a power amplifier and the correct thing to do is try something else.
I had to actually measure it, because to my ear it sounded OK.
This is but one example, I'll spare you the others. Protect the innocent and what not.
My personal experience dictates that owning a signal generator and distortion analyzer or a full on audio analyzer will really help to keep you on the true path and keep you from chasing rabbit holes that lead to lower performance rather than higher.
The 12BH7 is my favorite for the voltage gain tube in my VTA ST70.Perhaps I got lucky, but my Dyna/VTA went from very good, to better, then better yet after some tube rolling. Only once did it sound like a step backwards, and those tubes were promptly returned according to supplier policy. It's subjective, but I like what I like....I'm thrilled with the transition from tube rolling from 12AU7 driver tubes to 12BH7a, and EH EL-34s to GL KT-66, then to TS 7581A output tubes. I knew going in that each of the tube changes would work and was approved by the manufacturer. You'll never know unless you try.
Until you own and use the test equipment you can't really contextualize how hilarious it is when people claim improvement by ear.
Once you've seen the reality of these "improvements" you can't unsee it.
So you lead the horse to water...
