Those KT-170 tubes remind me of early 50s Buick taillights.Tonight's KT170's Eye Candy!!!!!
cool that is something.A test fit using a high quality TUBEMONGER NOVIB OCTAL NOS GE-USA OMRON-JAPAN Socket Saver© with Vibration Reduction Base. I will power the Amp on later as I am Upgrading the Mundorf MCap EVO Silver Gold Oil (two front Gain Tubes) with either Mundorf MCap Supreme Silver Oil or V-Cap ODAM. Will test the Mundorf MCap Supreme Silver Oil with 200+hrs burn in.
View attachment 3154252View attachment 3154251
My 300i arrives today and as many have suggested, I'll start with the tubes at the front end if I decide to dip my toe into tube rolling. I may do it even if the amp sounds great (as I fully expect it will) just to see what this tube rolling thing is all about and I suspect rolling a set of 12AU7s will be a heck of a lot less expensive with rolling the power tubes.KT150s will work and will likely last for over 10-12 years since they will be so under biased and under spec'd. To really hear what the 150 sounds like a person should give them a bit more bias than a KT88. If you are using an EVO 300 to driver L100s you really don't need more power, go for the sound that you really like. There are tons and tons of 12AU7s, 5814s and 6189s on ebay from some good sellers all will work in those input slots. If you want more sparkle on top try the RCA Clear tops, or Telefunken smooth plates. If you want a warmer sound try a pair of Mullards, or RCA black plates in the those first two slots.
One word ... WOW!![]()
Those KT-170 tubes remind me of early 50s Buick taillights.![]()
I would be looking at these places 1st before eBay. Upscale Audio, Tubemonger, Tubedepot, Viva Tubes. I have purchased Tubes on eBay from BULLzTUBEz, but anyone on eBay, you NEED to purchase a Tube Tester to verify the tubes. Plus, a TT should be in one's life with Tube gear.My 300i arrives today and as many have suggested, I'll start with the tubes at the front end if I decide to dip my toe into tube rolling. I may do it even if the amp sounds great (as I fully expect it will) just to see what this tube rolling thing is all about and I suspect rolling a set of 12AU7s will be a heck of a lot less expensive with rolling the power tubes.
Thanks for the suggestion. Do you have any eBay sellers you'd recommend?
