frankhertz
Welcome to AK, I'd try and keep the crossover on the sub as low as possible without creating any dips in the bass response. Also don't turn up the output level of the sub too high. You don't want the sub to call attention to itself. You may already know this.
You might want to upgrade your sub if your mainly into 2 channel music. For not a lot of money a little REL, T/5i sub would probably match your ProAcs very well in a smallish room. You didn't say how big your room is (?)
Thanks for the welcome. The room is about 4 m by 4 m. I have set the crossover to 80 Hz with the volume set relatively low at present. The bass from the sub does not seem to be overpowering the rest of the frequency range. I will look into your recommendation for a new sub.
Thanks,
