Long story short, Unit was working fine after not being plugged in for quite some time, then it let some smoke out and shut off.. Took a look around inside to find burned resistors on both the F-2808 (power supply) and F-2806 (driver amp) boards. The Resistors on the 2806 are so badly burned that no clue as to there value is left. I found a manual but, conveniently, every part cooked on the boards are omitted from the parts lists in the manual. One other thing I've been trying to figure out, is this the root of the problem? or was it more likely something else in the system that failed first causing these resistors to catch a little more than they were rated for..
In summary, If there's any sansui gurus out there willing to contribute the .02 I would be greatfull. Any info as to the values of R3 on the 2808 and the values of R25, R26 and R27 on the 2806 board would be awesome. As well as any clue as to what may have caused this failure.
Thanks in advance,
Steve Cap
Thanks in advance,
Steve Cap
