Function Board (NA06832) Schematic NAO6877
Capacitors: Schematic / Replacement
C101 220 uF 6.3v Found 100uF /6.3v Tant 100 uF 10v UKLA101KED Nichicon LL
C102 220 uF 6.3v Found 100uF /6.3v Tant 100 uF 10v UKLA101KED Nichicon LL
C103 220 uF 6.3v Found 100uF /6.3v Tant 100 uF 10v UKLA101KED Nichicon LL
C104 220 uF 6.3v Found 100uF /6.3v Tant 100 uF 10v UKLA101KED Nichicon LL
C105 33 uF 10v Found 100uF /10v Tant 100 uF 16v UKL1C101KPD Nichicon LL
C106 33 uF 10v Found 100uF /10v Tant 100 uF 16v UKL1C101KPD Nichicon LL
C107 33 uF 10v Found 100uF /10v Tant 100 uF 16v UKL1C101KPD Nichicon LL
C108 33 uF 10v Found 100uF /10v Tant 100 uF 16v UKL1C101KPD Nichicon LL
C109 100 uF 25v Electro 100 uF 35v UKA1V101MED Nichicon UKA Series
C110 100 uF 25v Electro 100 uF 35v UKA1V101MED Nichicon UKA Series
C111 100 uF 25v Electro 100 uF 35v UKA1V101MED Nichicon UKA Series
C112 100 uF 25v Electro 100 uF 35v UKA1V101MED Nichicon UKA Series
C121 1000 uF 6.3v Electro 1000 uF 16v UKA1C102MPD Nichicon UKA Series
C122 1000 uF 6.3v Electro 1000 uF 16v UKA1C102MPD Nichicon UKA Series
C127 0.056 uF FE 563 100 NCC (Blue Film) 0.056 uF 400v F461BB563F400A Kemit Polypropylene
C128 0.056 uF FE 563 100 NCC (Blue Film) 0.056 uF 400v F461BB563F400A Kemit Polypropylene
C129 0.015 uF FE 153 100 NCC (Blue Film) 0.015 uF 400v PHE426KJ5150JR05 Kemit Polypropylene
C130 0.015 uF FE 153 100 NCC (Blue Film) 0.015 uF 400v PHE426KJ5150JR05 Kemit Polypropylene
C135 3.3 uF 50v Electro 3.3 uF 63v KS2C043301K00JO Wima MKS
C136 3.3 uF 50v Electro 3.3 uF 63v MKS2C043301K00JO Wima MKS
C139 10 uF 35V Found 3.3 uF 50v Electro 3.3 uF 63v MKS2C043301K00JO Wima MKS
C140 10 uF 35V Found 3.3 uF 50v Electro 3.3 uF 63v MKS2C043301K00JO Wima MKS
C141 1 uF 50v Electro 1 uF 63v MKS2C041001F00JA Wima MKS
C142 1 uF 50v Electro 1 uF 63v MKS2C041001F00JA Wima MKS
Transistors Schematic / Replacement
TR101 2SC1775 NPN, 90V, .05 A, .2W, hFE = >400, 110 MHz KSC1845
TR102 2SC1775 NPN, 90V, .05 A, .2W, hFE = >400, 110 MHz KSC1845
TR103 2SC1775 NPN, 90V, .05 A, .2W, hFE = >400, 110 MHz KSC1845
TR104 2SC1775 NPN, 90V, .05 A, .2W, hFE = >400, 110 MHz KSC1845
TR105 2SA673A (C~D) PNP, 50V, .5 A, .4W, hFE=60, 40 MHz (Ve - sat .6V) KSA1013
TR106 2SA673A (C~D) PNP, 50V, .5 A, .4W, hFE=60, 40 MHz (Ve - sat .6V) KSA1013
TR107 2SA673A (C~D) PNP, 50V, .5 A, .4W, hFE=60, 40 MHz (Ve - sat .6V) KSA1013
TR108 2SA673A (C~D) PNP, 50V, .5 A, .4W, hFE=60, 40 MHz (Ve - sat .6V) KSA1013
TR109 2SC1775 NPN, 90V, .05 A, .2W, hFE = >400, 110 MHz KSC1845
TR110 2SC1775 NPN, 90V, .05 A, .2W, hFE = >400, 110 MHz KSC1845
TR111 2SA872 PNP, 90V, .05 A, .2W, hFE = >400, 110 MHz KSA992
TR112 2SA872 PNP, 90V, .05 A, .2W, hFE = >400, 110 MHz KSA992
TR113 2SA872 PNP, 90V, .05 A, .2W, hFE = >400, 110 MHz KSA992
TR114 2SA872 PNP, 90V, .05 A, .2W, hFE = >400, 110 MHz KSA992
TR115 2SA777 (Q~R) PNP, 80V, 1 A, 1W, hFE = 90-220 (100 typ), 120 MHz) KSA1220AYS
TR116 2SA777 (Q~R) PNP, 80V, 1 A, 1W, hFE = 90-220 (100 typ), 120 MHz) KSA1220AYS
TR117 2SA1509 (Q~R) NPN, 80V, 1 A, 1W, hFE = 90-220 (100 typ), 120 MHz) KSC2690AYS
TR118 2SA1509 (Q~R) NPN, 80V, 1 A, 1W, hFE = 90-220 (100 typ), 120 MHz) KSC2690AYS
Diode
D101 HV-46R / VD1212 Varistor Double 1N4148
D102 HV-46R / VD1212 Varistor Double 1N4148
Fuse Resistor
FR101 390 ohm/25 mA 390 ohm, 1/4 Watt 390 Ohm, 1/4 Watt, 1% Metal Film
FR102 390 ohm/25 mA 390 ohm, 1/4 Watt 390 Ohm, 1/4 Watt, 1% Metal Film
FR103 33 ohm/85 mA 33 ohm, 1/4 Watt MF1/4DCT52R33R0F 33 Ohm, 1/4Watt, 1% Metal Film
FR104 33 ohm/85 mA 33 ohm, 1/4 Watt MF1/4DCT52R33R0F 33 Ohm, 1/4Watt, 1% Metal Film
FR105 33 ohm/85 mA 33 ohm, 1/4 Watt MF1/4DCT52R33R0F 33 Ohm, 1/4Watt, 1% Metal Film
FR106 33 ohm/85 mA 33 ohm, 1/4 Watt MF1/4DCT52R33R0F 33 Ohm, 1/4Watt, 1% Metal Film
