That is amazing work! I have a CA-2010 in need of restoration and am just waiting for the time and equipment to do this kind of thing. Otherwise, I might just have someone with more expertise do this for me. You definitely have some mad skills.
As someone with no expertise about to undertake this exact project on a ca2010 I took it to a repair shop and they quoted me $800-$900 for less work than this so I’m going to learn by doing haha. Great post here. Really helpful.Unless you have obvious issues with noise or something else, or you're crazy like the OP ;-), I would start with just replacing electrolytic capacitors, tantalum capacitors, and cleaning all switches and pots per protocol. if you have no expertise for this kind of work, I would definitely recommend shopping it out to someone else, because the 2010 is absolutely worth a couple hundred extra dollars at the end of the day to make sure the job is done right and the unit is still working when the solder smoke clears!
IMHO No... OEM output transistors have a much better bandwidth than the Onsemi replacement outputs.but is there any real value in proactively replacing the main power outputs and pre-drivers?
Still some available but there on backorder.KSA1220AYS outdated and no longer available
https://www.mouser.com/ProductDetail/Toshiba/TTA006BQ?qs=B6kkDfuK7/BafvTE/b3gJA==2SA777 Q,R outdated and no longer available
Any other ideas?
Start manufacturing parts in the USA...Other options
2SC1116 ----> MJ21194G2SC11116
This is a CA-2010 thread.
Some New LEDs / MOD:
That will work..1N4007?
I am being told that I have DC on one or both Main Boards. I have checked every component on both boards and have not found anything defective. Since these boards become buried in the heat sinks when installed how does one troubleshoot them?
That looks like a CA-1010? Probably good to clarify that since you posted on a CA-2010 thread. I would suggest creating your own thread at this point.
