Up first was the main board - power supply and amp.
Main Control Board / Amplifier (NA06909-1)
C633-C634 – Original 10uf 25v (signal) / Now UKL1V100KDDANA
C637-C638– Original 2.2uF 50v (signal) / Now WIMA MKS2C042201K00KO
C709-C710 – Original 47uF 6.3v (signal) / Now 47uf 25v UKL1E470KEDANA
C713-C714 – Original 220uF 6.3v / Now 220uF 16v UKA1C221MED
C723-C724 – Original 100uf 35v / Now 100uF 35v UKA1V101MED
C727-C728 – Original 4.7uF 6.3v / Now 4.7uF 63v WIMA MKS2C044701M00KO
C743-C744 – Original 1uf 50v / Now 1uF 63v WIMA MKS2C041001F00JA
C745-C746 – Original 1uf 50v / Now 1uF 63v WIMA MKS2C041001F00JA
C751-C752 – Original 1uf 50v (BP) / Now 1uF 63v WIMA MKS2C044701M00KO
C801- C802 – Original 22uf 25v / Now 22uF 35v UKL1V220MEDANA
C803 – Original 4.7uf 35v / Now 4.7uF 63v WIMA MKS2C044701M00KO
C804 – Original 33uf 16v / Now 33uF 35v EEU-FM1V330 (protection, 25V would be fine)
C807 – Original 1000uf 50v / Now 1000uf 50v (UPW1H102MHD ) (power)
C808 – Original 100uf 50v / Now UPW1J101MPD 100uf 63v (power)
C809 – Original 47uf 25v / Now 47uf 50v UPW1H470MED (power, 35V would be fine)
C810 – Original 47uf 25v / Now 47uf 50v UPW1H470MED (power, 35V would be fine)
C811 – Original 47uf 25v / Now 47uf 50v UPW1H470MED (power, 35V would be fine)
C812 – Original 470uf 25v / Now 470uf 35v UPW1W4701MPD (power)
C813 – Original 220uf 16v / Now (power) 220uF 25v UPW1E221MPD (power)
C814 – Original 100uf 50v / Now (power) Now UPW1J101MPD 100uf 63v (power)
C815 – Original 100uf 50v / Now (power) Now UPW1J101MPD 100uf 63v (power)
C816 – Original 100uf 63v / Now UPS2A101MHD1TO 100uf 100v (power)
C817 – Original 100uf 63v / Now UPW1J101MPD 100uf 63v (power)
C822 – Original 10,000uf 50v / Now 12,000uF 80v Chemi-Con ESMH800VNN123MA6 (main filter)
C823 – Original 10,000uf 50v / Now 12,000uF 80v Chemi-Con ESMH800VNN123MA6 (main filter)
C824 – Original 47uf 6.3v / Now 47uf 16v UPW1C470MDD (power)
C825 – Original 10uf 16v / Now 10uF 25v UKT1E100MDD
C826 – Original 10uf 16v / Now (power)
D701-712 – Diode 1S1555 / Now 1N4148
D801 – Diode 1S1555 / Now 1N4148
D802 & D805 – Diode 1S1885 / Now 1N4004G
D808-D811 – Diode 1S1885 / MUR220RLG (2A/200V UltraFast)
TR609-610 – Original 2SC1213 / Now KSC2383
TR701-TR704 – Original 2SA872 / KSA992 (1st differential pair / all HFE matched – shrink together)
TR705-TR706 – Original 2SC1918 / Now KSC1845 (HFE matched)
TR707-TR708 – Original 2SC458 / Now KSC1845 (HFE matched)
R709-TR710 – Original 2SA844 / KSA992 (HFE matched)
TR711-TR712 – Original 2SC1918 / Now KSC1845 (HFE matched)
TR713-TR714 – Original 2SC1628 / Now KSC3503 (Rework Legs)
TR715-TR716 – Original 2SC734 / Now KSC1815YTA
TR717-TR718 – Original 2SA561 / Now KSA1013YTA
TR719-TR720 – Original 2SC1624 / Now MJE15032G
TR721-TR722 – Original 2SA814 / Now MJE15033G
TR801, TR802, TR804 – Original 2SC1917 / Now KSC1845
TR803 – Original 2SA844 / Now KSA1015YTA
TR805 – Original 2SB544 / Now KSA1013YTA
TR806 – Original 2SD234 / MJE15032G
TR808 -809 – Original 2SD400 / Now KSC2690AYS
VR701-VR702 VRs (5K) / Now 3386F-1-502LF
New Panasonic Relay (Direct Replacement)
Some Before Pics:
Bottom cross members / supports include ground pads. I created some additional ground straps / wires after these were removed.
Input Pair - Replaced.
Some Crazy Leg Action
As you see the original filters were 5 lug pattern - anyways no problem to get them to work.
