It doesn't really make sense you would suddenly hear both channels of a CD coming out of the D540 if you are still using the same set of bad RCA inputs (either Tape or Video) on the 930 that didn't allow you to hear stereo CD sound coming out of the 930 directly in the first place when used as a standalone unit.
Hmm that is interesting. Thanks for your response. If i put my volume to 75% to even out the difference i would probably cause the police to knock on my door.My D940 receiver has slowly developed a channel imbalance over the past few years. Its in the pre-amp section because the amp works just fine if I feed it a different source. The preamp imbalance problem comes from the volume control. At normal listening levels, there is imbalance. However, when the volume knob is rotated ~75% or more (~2-3 o'clock) the balance is fine. I haven't figured out how to service the variable gain volume knob, so I've left it alone. So now when I use the Proton D940 I have a Schiit Sys attenuator ($49) inserted between the pre-out and amp-in. I turn the volume on the D940 up to ~75% and use the Sys to control the volume. It works perfectly.
Thank you for your tips AOS. I have noticed the volume switch has a slight crackle sometimes when moved. It def can use some cleaning and by your advice i will clean the pots and other switches before diving in too deep. Tracking down a service manual will probably be the most difficult task.On every new (to you) amp/ receiver there are two things you should do, or when you have intermittent channel issues. First, spray all the switches, pots and dials generously with contact cleaner from the inside, followed with DeOxit Red for buttons and switches, DeOxit Green for dials and sliders. I've seen benefits from spraying the same switch three separate times in a row. Sometimes you think it's enough after one good spray and it's just not. Clean more. Then check/ adjust idle current/bias as according to the Service Manual. You have to do these things first before considering replacing anything with a channel imbalance or temporary audio dropout. If that does nothing, then start looking for anything obviously out of sorts under the hood- domed caps, burnt components/ sections of the board etc. If that looks ok, then it starts to get a little more involved, but you should at least make sure to take all the easy steps first.
I noted this slight damage near the volume switch but i dont think it is my problem.
PROTON - far from junk
Hey JS, ive since found the pre-amp is dodgy on the 540 (total loss R channel) and the FM circuit on the 930 is also dodgy (60% loss R channel).I don't think there's anything to be worried about there. Solder joint looks solid...there's just some flux that wasn't cleaned up.
Heya JS thanks for the tips. Pretty sure i have tried most things including spray cleaning the pots. Tried different RCA cables and in different inputs but the problem remains elusive due to my lack of electrical skill and test equipment. Im pretty happy with the outcome at this stage. If anything more fails i guess i will need to ship the unit to a repairer. Nearest repairer to me is about 4 hour return drive.It is sometimes instructive to play around with the pre-amp to diagnose it a little. Things I do:
- try different inputs. I can supply line-level inputs to CD, Tape 1, and Tape 2 and sometimes the sonic challenge is in only one input. Then you know to look at connections and switches on that input
- adjust the tone controls. Sometimes defeating tone controls (I don't recall offhand which controls are present on the D540, so forgive me if I err) -- by turning off loudness, or subsonic filters (infra-defeat), or simply twiddling the bass/treble knobs -- can eliminate or worsen the issue which then gives you information about where in the circuit you need to investigate.
Oxidation of the pigments seems to be the consensus. No one has run a chemical analysis that I'm aware of. I saw one of these on ebay and posted about it. There was a small discussion, but I couldn't find the thread when I looked. Maybe I can find it later.Does anyone know why some of the D540 amps face plate turn copper in colour?
Difficult to get a unified look happening but its pretty cool in some angles.
View attachment 2344314 View attachment 2344315
https://audiokarma.org/forums/index.php?threads/what-happened-to-this-faceplate.859190/
