Billfort
Addicted Member
Now that I’ve spent a few weeks with this new set-up, I thought I’d post some thoughts – particularly on the SOtM sMS-100 I got from www.audioconnections.ca – the Canadian distributor Sonore put me in touch with.
The sMS-100 is a simple, lean, DLNA renderer that only does 1 thing – stream music via USB - and it seems, does it very well once sorted. I like that it’s hard wired via Ethernet, has an external power supply (providing options) and is not a bad-ass tweaked PC – the more I learn about tweaking PCs to feed DACs, the more I don’t want to go down that sink-hole. It’s pretty close to a plug-in dedicated audio DLNA streaming appliance that lets you avoid the computer geek side of this and just get to playing music accept for…
Jriver>sMS was a challenge to get configured but with a few network changes, firmware upgrades and a lot of help from Jesus at Sonore and Trevor at Audio Connections, it seems to have stabilized and now streams all formats up to 2xDSD. Occasionally, the whole thing will lock up but lately, it’s been trouble free and problems seem to be mostly related to the JRiver music server PC and remote control of that PC – the SMS seems solid.
I’m not sure if (up to) DSD128 is possible with all of the light-weight linux based streaming appliances like the Pi, CuBox, beaglebone etc., or if they can interface with Jriver’s DLNA implementation, but I’m really seeing the wisdom of this approach. A lot of ‘ifs’ to consider but they might prove to be a cheaper route to doing this (if you can figure out how to build and configure them, if they can play all the formats you want, if you are happy with player options, if you can find help when you need it etc.). For me, paying a little extra to be close out of the box and to have the support I had available was well worth it.
Another software option I’d like to investigate is Signalyst’s HQPlayer which seems built around the concept of streaming everything as DSD128 and is supported by the sMS-100 in Network Audio Adapter mode. I gave up on HQPlayer in the past after a quick trial a while back as I think this product needs more computer power than my PC has to do it’s on-the-fly conversion, but since Jriver doesn’t seem capable of working in this mode (when using DLNA), I will try it again.
Jriver now runs on the PC in another room, I remote control it with an app on a phone and the SMS does its thing completely silently in the listening room – simple, clean and configured only for audio. I select music using the great Jriver interfaces and press play – nice and simple. As complicated as it gets is switching sources between the AN and Concero DAC on my pre-amp if I want a different taste on redbook, maybe changing configuration a bit on the Concero remote, but that’s it.
The external power supply of sMS has proven to be a nice benefit and the fact that the Concero is USB powered means it might be stepping up right along with the sMS when I upgrade the PS. Replacing the wall-wart with a bench style linear/regulated supply made for a nice improvement overall that was a little surprising considering how cheap a supply like this is on the used market. Current requirements for these lean devices is low so even with some headroom it’s pretty easy to find dead quiet (fanless) and much better performance than you’d get with any ATX style switching supply that would end up in a PC.
