Hello. Pretty much a newbie just getting into fixing up older equipment. Playing with an old Rotel Rx150A. 12wpc I think, very simple. Left channel is good, right is fuzzy and hissy. No real diagnosis, just playing with it so I can learn. Deoxed the pots, looked for any burnt components etc... Decided to start replacing caps. Did the main ones. Little louder and clearer, but right channel still fuzzy. Started on smaller caps. Randomly picked the two largest ones near the heatsink and output transistors (16v 470uF I replaced with some 25v 470uF I had). Installed one well, missed the polarity on the second.
Started the receiver up. FIXED! Both channels equal and clear. Smell smoke, shut it down, cap I installed backwards was blowing up. Take it out, put a new one in correctly, hiss and static back?!!
Thoughts?
As well, I put my voltmeter on the 4 output transistors (Toshiba 2sc789) just as a learning exercise. I get readings in every direction and every possible configuration. I think they are PNP, but I assume when I don't get a single 0 reading, they are all shot? I have looked into ordering replacements. Does that explain why when I shut it down the sound slowly peters out over 4-5 seconds? Does it help explain why the reversed cap still produced sound?
Any and all thoughts and opinions and pointers for a new learner are welcome.
Thoughts?
