Ok so I put everything back on.. minus the cardboard...... which... apparently was a mistake, because when I flipped the switch everything came on again but this time there were little crackling noises, almost like light welding :S So I put the cardboard on and then tried again.. no crackling this time.
Now I have a little test speaker (some cheap tiny thing that came out of computer speakers) hooked up to it. I didnt get anything through it.
So I tried the front headphones... nothing, but rear headphones i got sound. It was very scratchy and noisy.. kind of popping a little if I turned it up.. and I'd say quiet too. All VUs showed movement (albeit not all the same) when music was playing through it.. except for the front left (again.. like at the beginning).
No fuses blown. Oh and also.. i noticed that when I had the front headphone plugged in.. after a little while I saw a tiny trail of smoke coming from where the headphone connects (inside the unit).
So.. whats all this stuff mean? :S
Im at a loss as to what this cardboard is too, Im with Jim on this one....you will have to explain what you mean.......
Now, bad idea to just fire it up and plug some signal into it and listen for some sound.....
You have replaced transistors and other components....you cant just turn it on and hope for the best....
What you need to do it fire it up, and if it all appears to be working with no fires and smoke coming out of it and crackling welding type noises, the FIRST thing to do is go immediately to the bias to check and adjust........
Measuring the bias is going to tell you a lot about the condition of the output transistors and driver section.....
If you have bias current flowing in the range it is supposed to be, you are in good shape.......
No bias current, too much and unable to adjust it down, not enough and unable to adjust it up is going to tell you to start looking into various things.....
You need to make these measurements and report back.......
Next you need to measure the DC offset, now you will have to do this as Jim said with the headphone socket, because the amp will be in protect mode and the relay will have disengaged the speaker outputs.....
I would imagine there is a lot of DC on some of the outputs, you need to find out which ones and how much, and report back..
Once we see what is going on we will know what we are dealing with........
