kevzep
Its all about the Music
Ok guys about the cardboard... I first showed it in post 92. Here's the pic
I probably did get a little carried away yesturday :/ My apologies.
I had the multimeter and was trying to test bias and DC I forgot when in protection it dosent show through the speaker terminals
So I'll test with the phono plug shortly and report back.
Also, after it was powered on and running for... i'd say maximum of a minute the heatsinks were very cold on the back. BUT, the little sanyo D315d transistor on the pre power supply board was warm.. not so hot that I couldnt touch it, but it was warm indeed.. I thought I should mention that.
Thanks guys![]()
Measure the bias current........
You say you were tying to measure the Bias, how were you trying to measure it?
Rail fuses need to be pulled and your meter in current measuring mode needs to be put across the fuse terminals to get your bias current reading........
Do this before the DC offset....
