Just to be clear, it just provides a very stable oscillator reference frequency, set by a quartz crystal, but you still have to adjust or calibrate the setting so that the speed will be correct. Once it’s calibrated (which is normally done at the factory), it should be spot on for speed accuracy, unless components in the oscillator drift in their specifications, or variable components (e.g. trimpots) get moved or vibrated so that their setting is changed.
Quartz crystals provide a very stable source for setting frequencies, which hardly moves with changes in temperature – see
http://en.wikipedia.org/wiki/Crystal_oscillator . The quartz locked turntable was originally developed by JVC in about 1974, and was traditionally used on the most expensive turntables from many Japanese, American and European manufacturers.
The service manual (unfortunately not available on vinylengine for the Marantz 6350Q) usually describes how to calibrate the quartz lock. Calibration sometimes is simple, requiring only a screwdriver and digital multimeter, if a stroboscope is included in the turntable as standard, but in other cases may require a stroboscope card to check speed, and more complicated and expensive instruments such as a CRO (Cathode Ray Oscilloscope), which only electronics service people commonly possess. It just depends on the manufacturer as to how easy it is, and they vary quite a bit – companies such as Sony, who are at the forefront of electronics, usually made it quite hard – their engineers were obviously more attuned to inventing than making things easy for service people!
In some cases, manufacturers such as Marantz may have left it up to their local distributors to calibrate before sale, and if that wasn't done, then they may have not been accurate for speed even when new, when the quartz lock was switched on.
