Sorry, I don't use typical multi-mixed recordings as a reference.
Evidently, you don't listen to live, unamplified music or are aware of any number of recording labels who have no use for that kind of gear.
Sorry, I go to see live unamped music all the time, get to hear regular people also playing music in small church settings with real instruments. If you have Chesky, Sheffield and the like labels, they all used some type of mixing, eq'ing, and switching console, whether it was custom built tube gear or otherwise. They might have even used just 2 channels of a multi-channel unit.
The reality is every recording uses some type of "Gear" to get the acoustic sound into a mixing device, and then to the recording medium. The arguments for minimalist techniques and elitist (snobbish?) gear have been around for a long time, and for some in the audiophile world, extends their own biases about what "should" sound good, and everything else "must" sound "less good". But great recordings can be made with many different techniques and gear in between. Choices of mics for example can shade or color an instrument or recording.
If you visit studios that created great recordings, or even onsite recordings at great venues, you'll find plenty of fairly common cables, consoles, and connectors. Very few will have the gilded gold plated connectors (no RCA's for sure, most connectors are XLR's), hundreds of feet of fairly common mic and connecting patch cables and not much DeOxit in sight.
I suppose the only recordings that would suffice would be a two mic setup running into a two channel custom built console straight to the cutter head or analog (tape) recording medium (oh and then we have to account for the recording monitors, amps (SS or tube) and the acoustic space the engineer is listening in, and the hearing and "artistic tastes" of the engineer and artist. Then there's any post production "adjustments").
Obviously, any digitial recording cannot possibly be good because of the complexity of any AD-DA conversion, the hundreds and thousands of transistors in the converters, filters, and clocks, and of course the particular analog buffers and amps (discrete or integrated circuit based) that eventually drive all the output and inputs to the recording medium.
And all this is silicon solid-state based for the most part although there are plenty of tube based products that are used to shape sound. But then the artists must be "altering" the acoustics of what they want you to hear with all that outboard gear, let alone their particular choice of instrument. Frankly, I don't much care for Steinway pianos, Yamaha are decent but tend to be bright in North America, and Bosendorfers are great but fairly unknown in NA.
I guess I just don't like to see or hear someone basically say that the vast majority of people working diligently in the audio recording business don't know what they are doing or how to do it. Audiophiles tend to think of themselves as all knowing at one end of the production spectrum and that gives them carte blanche to criticize or denigrate the work of the artist/engineer/producer team, and the companies that produce equipment to create the recordings.
If a purist effort is the only thing that will suffice, you're entitled to that viewpoint. I personally think there's plenty of great music and recordings recorded on all kinds of gear that happens to sound great despite the lack of "audiophile" qualifications.
