It is a EQ loop. Same as a tape on a receiver IIRC.
External Processor Selection??? Section?
Barney
Thank you Sir, that really helps! If I wanted to connect another pre-amp, this is what I would use, correct??? I have found the service manual online, but have been unable to find the user manual. I will PM you, as suggested.External Processor Switch. I own an A7090 since new over 30 years ago and it is a fine integrad. This switch routes the signal coming out of the pre to whatever is connected to the jacks in the back and back to the main amp. Back in the day, people connected mostly equalizers and some reverberation amps. When not depressed, the signal goes from the pre to the main internally. That is why you do not have jumpers in the back as some amps had at the time. If you send me a PM with you e-mail and I will be glad to scan the original owners manual and send it to you. Just give me a couple of days. Now. if you could get your hands in a pair of Onkyo SC90MKII which I also got with my 7090 you will be set. The problem is that they are practically non-existing. Not many were brought to the US and they were kind of expensive, $499 each. If you try a Goggle search for them all you get is a post here where I name what Onkyo gear I have, and a whole bunch of links in Germany and Italy. At the time, around 1980 Onkyo was very strong in Germany.
+1 to everything in this post.:yes:External Processor Switch. I own an A7090 since new over 30 years ago and it is a fine integrad. This switch routes the signal coming out of the pre to whatever is connected to the jacks in the back and back to the main amp. Back in the day, people connected mostly equalizers and some reverberation amps. When not depressed, the signal goes from the pre to the main internally. That is why you do not have jumpers in the back as some amps had at the time. If you send me a PM with you e-mail and I will be glad to scan the original owners manual and send it to you. Just give me a couple of days. Now. if you could get your hands in a pair of Onkyo SC90MKII which I also got with my 7090 you will be set. The problem is that they are practically non-existing. Not many were brought to the US and they were kind of expensive, $499 each. If you try a Goggle search for them all you get is a post here where I name what Onkyo gear I have, and a whole bunch of links in Germany and Italy. At the time, around 1980 Onkyo was very strong in Germany.
Mmmm, not sure about that. Seems to me that if this works like a typical tape or EQ loop, you would then have two active pre-amps in the chain. Kind of wonky. And complicated and noisier.
To utilize another pre-amp and actually bypass the one existing in the Onkyo, you need the "pre-out" and "main in" (or vice versa?) connections, if not in use connected together with a jumper of some sort.
:saywhat:
So does this thing have pre-out, main-in or just tape loop?
I believe there is a big difference, as discussed above...
Hi: Last things first, sorry I wouldn't think of parting with it! Other than having to de-oxit the switches periodically I have done nothing to it in the 3 or so years that I've owned it. It's kind of a shame that with all the features the 7090 has, I have so far only used the aux and phono inputs.". To listen to the sources you would need to have the EPS switch on. That way will be using the outside pre-amp and the 7090's amp. You can also use the 7090's pre-amp and an outside amp. To do this you would have to connect all your sources to the 7090 and connect the 7090's pre-out to the outside amp's in, and all your speakers connected to the outside amp. Also depress the EPS switch. If you also want to have an equalizer, or any other sound processor, you can connect it between the pre-amp you are using and the amp. If you want to complicate things you can also have an outside pre and an outside amp conected to it and choose which ones to use, thanks to the EPS switch and not having jumpers in the back. This is a bit more complicated and if you are interested I can tell you how to do it. This is a very versatile integrad. Did you notice you can connect 3 phonos, 2 MM and 1 MC, 2 tape decks with monitoring for both and dubbing from tape 1 to tape 2 or from tape 2 to tape 1, 3 sets of speakers from 4 to 16 ohms, and 3 way adjustable power indicators. Very high power (it is underrated) and low THD and Intermodulation (which nobody is talking about these days but is very important I believe). As for the manual, I'll scan it tonight when I get home and send it to you. If not able to do it tonight I'll do it tomorow. The only thing left is that I hope you don't like it and even hate it. Then I'll be glad to get it off your hands.
It has pre-out, main-in, plus 2 of what is called tape loops, or tape monitors.
I must be blind, I don't see the amin in?pre out???
They are there. Maybe, since these things are about 35 years old, the lettering is no longer readable, but you will be able to locate them once I send you the manual. Or maybe, like me, you need new glasses (just a joke). That's the beauty of EPS, you don't need jumper cables, or change cables for different options. Just push a button and you are done. Now, are you sure it is a 7090? It had 2 smaller brothers, the 7070 and the 7040, and I can't remember if they has the EPS switch and pre-out main-in jacks.
I'm also an old guy and those are the jacks, they just call them EPS and I think in and out. Here is a picture I found on Ebay and I highlighted it.
great Amp! I have it's little brother the A-7040. had it since new. watch that lettering!
