CIRCUIT ANALYSIS
Boy oh boy -- lots of observations being made and data being gathered, and a few problems uncovered as well. I hope I can present it all in a cohesive manner:
1.
Published Schematics: The first circuit I can find was published in a Radio & Television News article dated Nov, 1956. Unless a schematic of earlier dating comes along, I am considering this the original schematic of the amplifier. In Jan 1957, Fairchild published an updated schematic. It has mistakes on it, and includes general updates such as specifying GZ34 rectifier tubes and lowering output tube quiescent current, but the real take away is the unveiling of a completely revised NFB system and approach to tailoring the HF response of the amplifier. Sams came out with their folder on the amplifier in Dec of 57, which has its own errors, but makes the usual Sams effort of depicting both designs.
2.
Published Performance Specifications (of notable relevance):
As provided with their original sales literature:
A. Power Output: 65 watts at less than 0.5 IMD.
B. Frequency Response: +0/-0.5 db 20 Hz to 20 kHz at any level up to 70 watts.
C. Sensitivity: Less than 0.7 volts rms for rated output.
D. Hum and Noise: Greater than 90 db below rated output (<1 mv on 16Ω tap).
As provided in their Model 275 Instruction Manual (which also includes the updated schematic):
A. Power Output: 70 watts at less than 2% IMD.
B. Frequency Response: +0/-0.5 db 20 Hz to 20 kHz at any level up to 65 watts.
C. Sensitivity: Less than 0.5 volts rms for rated output.
D. Hum and Noise: 85 db below rated output.
Two observations from this data -- one minor, one major: (1) It looks like the power output wars reached even the Fairchild Corporation as well: Power Output was increased in part by allowing a wider distortion tolerance, and (2) Based on my work with a number of other amplifiers that were in production during this time frame, it is highly likely that the original design was found to have HF stability issues relative to the quickly changing standard for stability that was taking place at that time (the original design had a number of elements that were acting to boost HF response, while the updated design has none of those, and elements installed to actually reduce it). Note again the relaxed distortion standard and importantly, the greater sensitivity associated with the updated circuit. This all speaks to a reduced NFB level (which the revised design has), as part of an overall effort to enhance (at least) HF stability.
The amplifiers here include (by in large) the updated NFB, HF stability, and Damping Controls circuits (other than the missing components in the damping circuit), and the effect of the changes is notable. Fairchild's published specifications (any of them) are rather general in nature, specifying no THD performance, and frequency response only up to 20 kHz. The amplifier here meets the published frequency response performance, but with no information for response above that range, the only indication that can be had for proper performance in that region comes through a comparison made between the square wave presentation as shown in the Radio and Television article (surely made by the original design since that is what's presented in that article), and that produced by the amplifier here. And differences certainly exist, which are supported by the changes made to the updated version:
Note the square wave presentation at the bottom right of this page. From the description, it is a 6 kHz presentation made at 40 watts output, with the variable damping "at a minimum" (I believe what is meant here is with the control set for maximum damping -- i.e., the damping circuit turned off). The impedance tap being used is not stated, but it was quite customary in the day to perform all testing at the 16Ω tap:
Now, take a look at the scope shot here of a 6 kHz square wave made at 40 watts output, with the Damping Control turned off, as taken at the 16Ω tap:
The primary differences to note are the article's image shows a very flat and parallel top/bottom of the waveform, with tight corners. I have little doubt that most feedback amplifier designs with this display at this frequency in fact have HF stability issues. Now look at the square waves produced from the amplifier here. The tops and bottoms are not parallel (indicating notable phase shift), and the corners are well rounded, indicating a limited HF response.
When a more traditional 10 kHz square wave is used, the defects are exaggerated even further (the higher amplitude was just me being lazy and not equalizing the amplitude in both presentations):
Understand that a square wave is a fundamental frequency, with an infinite number of odd harmonics added to it. Therefore, it is generally understood that for a circuit to pass a square wave with reasonable fidelity, the circuit must be able to pass a band of frequencies that is equal to the fundamental frequency F/10 on the low end, to F X 10 on the high end, and do so with equal amplification and phase shift properties at all frequencies throughout that band pass.
The measured frequency response of the amplifier here (@1 watt @ 16Ω) is:
@1 kHz = 0.0 db (ref)
@ 10 kHz = +0.7 db
@ 20 kHz = -0.4 db
@ 30 kHz = -2.5 db
@ 40 kHz = -4.7 db
@ 50 kHz = -6.8 db
@ 60 kHz = -8.5 db
So the supersonic response drops off a cliff pretty quickly, which is exactly why the square wave shown is being produced. The kick at 10 kHz is likely being produced by the damping circuit components that remain in play even when that circuit is turned off. I have suggested to my client that the Variable Damping circuit should be eliminated, as it long ago became an anachronism, almost a fad that disappeared about as quickly as it appeared. Removing the circuit properly however would entail developing a new NFB and HF stability scheme, which can certainly be done -- but then that starts to beg other questions.
I've often stated that from my perspective, it is the circuit that creates the sound we hear -- not the character of the individual components. I know that cuts sideways with a lot of folks, and I appreciate that all opinions are valid. But my perspective is one that has been proven out many times over the years. Now
not wanting to start that debate here, where I'm going with this is that if you modify the circuit for provably better measured performance, what if that cuts against the sound that folks have come to know these amplifiers by? That is, it may very well be that it is because of the limited response and phase characteristics shown that folks enjoy the sound as much as they do.
I have long observed that more than just a few people would (often enough) rather listen to their little Maggy amplifier, than (no disrespect meant at all), a classic Mac amplifier that is darn near all but perfect in terms of measured performance (I have a C11 and MC240). Why is this? The Mac is extremely faithful to the original definition of High Fidelity, while the Maggy is (by comparison) limited in just about every way possible you can think of. I have concluded that it is the looser damping, more rolled off presentation of the Maggy that takes the edge off just enough, and loosens up the low end just enough, to make for a very enjoyable listening experience, even though it is certainly less accurate.
Now I'm hardly trying to imply that the 275 is akin to a Magnavox. Quite the contrary. However, it does have what effectively amounts to signal shaping circuits in the dual feedback paths (unique to the updated design) that can affect the reproduced sound. There are a whole bunch more tests to be made to determine the characteristics of these networks. So taking things a step at a time, I always try to consider all sides before taking that next step. A new network may produce a wow or nope, I like the way it was. But at least knowing the reality of what is allows the questions to be pondered before the next step is taken or decided. Comments always welcomed.
Now the Hum and Noise performance is an issue for another time, and needs addressing as well.
Dave
