DavidBalding
Member
Thanks didn't even think about that.Dave,
PM @nerdorama here, just click on his UN and then "Start a Conversation" posting an email addy on an open forum is not a good idea. I would edit that to while you can
Question for you and the group, I'm pulling the tubes out of the amp so as to minimize breakage while I pull the amp out of the cabinet. Any idea about the rectifier tube as to how it is removed? I don't want to pull hard on it. Attached is a picture of it's current state.Well that Amp looks like what I just restored in this thread:
https://audiokarma.org/forums/index.php?threads/rca-console-pull-project.977520/
I did modify it to make it a better stand-alone Amp but perhaps there is some info in there to help.
That worked! Thank you. Also is it normal to see a little, all I can describe it as cruddy looking at the top inside the tubes? This was one that looked pink previously.Looks like it has a keeper ring around the base. The ring has gripper points to grab onto the tube base. Press down on each side to release the grippers and remove the tube normally.
Found these...https://www.tedss.com/MPE11-.27-400-2 would these be a good replacement?Might as well get polypropylene film for 7 cents more than the 47 cent polyester... https://www.digikey.com/en/products/detail/panasonic-electronic-components/ECW-FD2W274K4/4271878
Axial leads would be nice but of the nine listed by DigiKey, none are in stock, 100 piece (or more) minimum order...
F&T and JJ make dual 500V electrolytics - (32 x 2 and 50 x 2) use separate ones for the low-voltage ones. RCA used 80 X 2, which is hard on the rectifier - I think 50 is plenty.
That 6BQ5 may be cooked... getter flash is almost gone. This amp would like matched pairs.
I'd imagine both left and right channels need to be balanced/matched?I'd have probably gone for 2 matched pairs, fair bet that if one set is tired the other ain't so awesome. New production are fine honestly.
I plan on replacing all 6 paper capacitors. Also repacking the two canned capacitors too. Do you think I need to replace the non paper ones too?It might be a good idea to replace all capacitors before you accidentally destroy the new tubes.
More worrisome is destroying the power transformer due to the main filter capacitors shorting out. Tubes can be replaced. Power transformers are also replaceable, but tend to be harder to find.It might be a good idea to replace all capacitors before you accidentally destroy the new tubes.
