I thought about it but since I couldn't find exact values for the caps I figured I'd throw the cans away. The boards worked really well.I see you used the Adapt-a-cap boards. They are handy but don't preserve the look if that is important. I have tbought of gluing the original can over the top. Would almost look original.
John
Since the radio section works I'll leave those alone. I did order a signal generator today so that I can do an alignment once it's all together. Thanks for the help.If this were mine, I'd change the can cap, the black sleeved electrolyic up near the front, and possibly those two white caps near the selector. The white caps would depend if they are paper or not. There are some ceramic tube caps with epoxy ends that are actually a film cap, and those usually hold up OK unless mechanically disturbed. The leads break internally and they go open circuit sometimes. The ones I'm thinking of are typically branded Ceracap.
Otherwise I wouldn't change any of the rest of it unless it was giving me trouble. Looks like mostly epoxy dipped film and ceramic types, both of which are reliable. The ceramics are probably tuner related and screwing with most of that will force a re-alignment.
Thank you. I didn't realize the dipped ones were film.I see about five caps to change - the dipped ones are film, the ceramic ones seldom go bad. And any in the IF or RF circuits will affect alignment.
Thank you! The turntable needs a little work. Oiling and a new cartridge but it plays. It sounds beautiful. I had a Brahms record playing during dinner that was my late grandfather's and the wife asked if we were hearing a record. She couldn't believe how clear and warm the sound was. This is the way records were supposed to be played. Nothing beats an analog sound.Nice looking turntable. Great restore. Hope you really enjoy it.
John
Yep and all the tubes are original. Everyone has a date stamp of 63. I was a bit worried that the ones that had red plated might have gone weak but it will crank up loud. Normal volume for me is 2 on the dial. Any higher and the walls start to rattle.Are those RCA solid getters? I have a set of those, similar tilted getter flash. Good sounding tubes, unfortunately mine are tired and give me somewhat less than full output but they still work fine. I just have to live with 9.5 watts instead of 12.
honestly there isn't anything worth listening to on AM in most markets anyway. I like antique radios, but I've sort of fizzled on collecting them simply because they just aren't much fun to use unless I create my own source of music for them.
Yes I did! We use the console everyday to play music.Did you finish the restoration.i just picked up the same exact unit
