The cans are pretty easy to restuff but not everyone likes to do it. I did one last week for a friend. I use an Xacto type razor saw and cut around the top of the bottom ridge. I score around using the saw backwards first and then use the scored indent to guide the saw. Get a very fine toothed saw. Drill holes through the bottom part for the new cap leads to emerge by the original terminals. I group the commons into a single hole in the middle which then needs to be reconnected to the original system ground. Since you have the wafer mountings, you just need to drill out the rivets. I glue the can top part back to the bottom with 2 part gray JB Weld and then wipe gently with acetone to smooth the join. Use a plastic glove. There are a number of threads about the process on AK.
These capacitor adapter pc boards are a convenient way to replace a can cap when the apperance and access isn't a problem.
https://msquaredcircuits.com/shop/
