Stuart,
Thanks for the link. I will read it when I get in from mowing.
I have M7's with the SD13 tweets. the woofs are 1218's. One is basically a gray cone and one may be a faded white( a replacement from the bay). It has extra writing on it that says: lowEff. ?? all 4 drivers are made in Japan. Don't remember when purchased. all have metal mounts and metal grilles.
mine are the black 40-2030 B's
RadioShack marketed a reciever that had a special equilizer stage for the M7 that extended the low end with just the flip of a switch. Anybody know the model number of that reciever?
One of my 2030C which is also has the Interan label's number is 1687 with a 1 a9 under it the other is 1481 with the same 1 a9 under it.
Cool. Thanks for the info.
Since yours are C's, could you also post where they were manufactured? So far, I'm finding Malaysia most common, Japan next and Korea rare. The sample pool is still small yet -- more data should yield a more accurate spread.
Forty lashes with a wet noodle.Nope, I stuffed it. You read right.
That makes sense, since much of the fiberglass I've seen *is* denser than the polyfill, so "smushing" the polyfill in there probably equaled the fiberglass's density. And ultimately, if the speaker sounds right, that's what matters in the end.I know that isn't the accepted philosophy. I don't know the absorptive qualities of bra stuffing (fiber fill) versus fiberglass that was intended for insulation. The fiberglass was more dense than I could have made the fiberfill. So I went whole hog!
